DON'T JB Weld anything, unless you want it f-d up! Fit it the right way...remove bracket, get an extractor and back it out. Check threads, clean them up (if needed), get new bolt & tighten-up. It's not a complex fix...IMO.
When applied correctly, JB Weld is barely noticeable.😎
