Stage 4 2018 RKS W/M520 andrews?
Old Oct 23, 2018 | 06:45 PM
redtwin's Avatar
redtwin
Default Stage 4 2018 RKS W/M520 andrews?
Doing some updates and changes.
1-Fueling cam plate and pump
2-Air cleaner/make the heads breath better
3-staying with SE high flow head pipe and installing Jackpot street outlaw mufflers/modified to fit 16 and under muffler inlet(we will see how it works exhaust might change)
4-M520 cam Fueling lifters,adjustable push rods
5-already have TTS tuner
Looking for any comments and other info that should or could be done while I am in there?
Like all comments good or bad.
Old Oct 23, 2018 | 07:13 PM
DTTJGlide's Avatar
DTTJGlide
Just depends on what you're looking to gain, the Andrews 520 doesn't look to be that much different the the SE515. Most people dumping the 515 are looking for more TQ down lower, not sure you numbers are going to change that much.
Old Oct 24, 2018 | 04:07 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Redtwin
Here's a link to a similar Stage IV build that your talking about.
https://www.hdforums.com/forum/milwa...rformance.html
Old Oct 26, 2018 | 07:49 PM
GLIDE50's Avatar
GLIDE50
Might need some valve springs with that cam.
Old Oct 27, 2018 | 06:57 PM
redtwin's Avatar
redtwin
Already have stage 4 so springs should be fine,but have decided to go with a different cam
Old Oct 27, 2018 | 07:20 PM
northern's Avatar
northern
Thumbs up
I love the Andrews cams, I have it in my shovelhead lowrider for 30 years and it still runs very strong. I now have a new Softail Slim and when it comes time to change a different stage it will be Andrews.
Old Oct 28, 2018 | 07:31 AM
redtwin's Avatar
redtwin
I am staying with andrews but with a new grind that will work with my set up,always used andrews on my past bikes with good results on my twin cams and evos
Old Oct 28, 2018 | 12:24 PM
DTTJGlide's Avatar
DTTJGlide
Which cam did you decide to go with, inquiring minds would like to know?
Old Oct 28, 2018 | 02:55 PM
redtwin's Avatar
redtwin
I Know it is not on there web site but I think it is going to be a M550?
Old Oct 28, 2018 | 07:06 PM
DTTJGlide's Avatar
DTTJGlide
Thanks for the reply, be interesting to see the specs, I'd suggest replacing the plastic lifter guides with S&S lifter cuffs, great low cost upgrade, be careful removing the guides as some have had the bolts break off when trying to remove them.
