1k Service
Old Dec 6, 2018 | 08:01 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by CSMHOG
ANY good independent shop can do your first service. We service all kinds at ours to include a lot of first service Harley owners. Our standard charge is $117 plus materials. We have the tools to activate your ABS when flushing and even check your infotainment for current updates, the only thing we can't do is update your ECM if HD has updated their flash. Honestly, that is probably the only upper hand the dealership has over anyone and that's only if your bike is completely stock.
The 1K includes a check of critical fasteners. How do you check them? Do you treat the ones with Loctite differently?
Old Dec 6, 2018 | 10:10 AM
strych9's Avatar
strych9
Originally Posted by Keithhu
Its not about how much time it actually takes, its about "bench time", a standard set time for each service. Bench time for this service is 3 hours. They charge that no matter how long it takes, so the name of the game for the tech is to get it done as quickly as possible. I've often been called 1 hour after I dropped it of, but guess what: charged for 3 hours.
That said, $621 does seem excessive. Sacramento, CA is an expensive place to do business, not sure what their bench rate is, but if its $150, 3 hours is $450 and with supplies and tax, its probably not far off.
I live in Michigan and I believe I paid $425, bench rate around here is $110, I think
More accurately, it's called "flat rate". I made a living off of flat rate for 10 years before changing careers. I am surprised that flat rate is that high for a 1K service. Who am I kidding...they don't call them 'stealerships' for nothing.
Old Dec 6, 2018 | 08:26 PM
CSMHOG's Avatar
CSMHOG
Every model has a critical fastener checklist depending on what time or engineering has determined what loosens or is life threatening, they’re listed in your service manual. It will also explain what should be done if found loose.
Old Dec 6, 2018 | 08:51 PM
judgedelta's Avatar
judgedelta
Sounds like the dealer was planning on using one type of lube in your bike and another type altogether on you...
Mittens01
Jul 4, 2013 09:23 AM
stricky
May 27, 2011 04:37 PM
hoethree
Jul 31, 2010 06:21 PM
medic4.life
Sep 16, 2008 08:30 AM
dastark
Jun 23, 2006 03:42 AM
