Tpms
"I also figured out that CVO wheels have 8,5mm diameter of valve holes.
Non CVO wheels have 11,5mm diameter.
The stem valve of the TPMS sensor are made for 8,5mm diameter.
How i solved this to fit an 8,5mm stem valve for 11,5mm valve hole?
I used the "rubber grommet 1" of the T-Valve from FOBO to fit it!"
That is a very important part of this puzzle. If you don't mind making these CVO sensors fit a Non CVO Wheel, then go for it. I personally think that making it seal properly, where it doesn't lose air, is a hit or miss proposition. There are many different kinds of wheels out there that we use so making sure that the "rubber grommet" fits properly might not work correctly with every senario. At least I don't want to take that chance.
You can install it on all wheels with 8,5mm diameter valve holes without any issues. This stem valve are made for 8,5mm.
If your valve hole of your wheel has a diameter of 11,5mm you have two options.
Option 1: Use a the rubber grommet of the FOBO T-Valve (cheapest solution, but you need to check if its fit)
Option 2: https://tirewatch.com.au/wordpress/?page_id=596 Tire Watch have the same sensors like the harley sensors. I contacted Tire Watch and they told me that there system fits on 99% of all wheels on the world (including 11,5mm).
So you need only the stem valves from them and the harley sensors for 100% fitment on 99% of all wheels.
You can order the stem valves as a spare part from them.
I have Enforcer wheels. And the rear enforcer wheel has the valve hole not in the middle of the wheel. So the sensor would also not in the middle of the wheel.
For that a dynamic balancing of the wheel is required and i only have the option for static balancing.
Static balancing is okay if the valve hole is in the middle of the wheel.
Because of that i cant follow it to get it working on my bike.
But i installed the sensor in the front enforcer wheel and used the rubber grommet of FOBO T-Valve, paired to the bike and it worked.
