Replace pushrods for Stage III upgrade?
Old Jan 8, 2019 | 01:08 PM
LowRiderGuy's Avatar
LowRiderGuy
5th Gear
Question Replace pushrods for Stage III upgrade?
I have a stock 2018 Sport Glide that I want to upgrade to Screamin Eagle Stage III. I know I need to do the Stage I changes (AC/muffler/retune) first. Do I need to changeout the pushrods in addition to the parts contained in the Stage III Kit? That’s the word from the dealer.
Old Jan 8, 2019 | 01:16 PM
Desertwndrr's Avatar
Desertwndrr
You shouldn't need to unless the base circle is different than the stock cam. Typically pushrods are cut and replaced with adjustables to same time during a cam swap. Where you are doing a Stage3 you will be popping the heads and rockers and you can just drop the pushrods in.
Old Jan 8, 2019 | 10:13 PM
tonyd2017's Avatar
tonyd2017
Default Push rods
i am going to keep my stock push rods when the time comes for a stage 3 good luck
Old Jan 9, 2019 | 10:38 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
No need to replace pushrods on a HD Stg III or Stg IV M8 kit the stock ones are fine. The problem comes from doing a Stg II as it takes more labor time to reuse the stock pushrods than the cost of new adjustable pushrods when doing the install, but the Stg III and IV require removing the heads anyways so the pushrods come right out at that point.
Old Jan 9, 2019 | 10:41 AM
Noisy Cricket's Avatar
Noisy Cricket
I had mine replaced when I did my stage III but only because I wanted the gloss black covers so I opted for the adjustable pushrods at the same time. It was not a requirement.
Old Jan 9, 2019 | 11:02 AM
RANGER73's Avatar
RANGER73
Installing adjustable pushrods is never required. But makes the Stg II more cost effective. Then everything after that the top end comes off anyway.
Old Jan 9, 2019 | 03:23 PM
Peter Quinn's Avatar
Peter Quinn
No you don't.The heads have to come off for the new Pistons,Cylinders and valve springs,Just keep the rods and followers in their same locations and orientation.All will be good.The Stage 111 offers the most bang for the $ in my book,enjoy!
Psycho Dave
Milwaukee Eight (M8)
21
Jan 14, 2025 06:41 PM
cmashark
Screamin Eagle CVO Models
14
Mar 10, 2017 08:18 AM
chico4
Exhaust System Topics
Jan 13, 2010 09:01 PM
ozzyg
Jan 12, 2009 07:06 PM
intruder400ex
Oct 25, 2005 11:02 AM
