Transfer Issue
Old Mar 11, 2019 | 12:52 PM
WAYJO's Avatar
WAYJO
Just sucks that we are all here trying to re- engineer a piece of machinery that we paid nearly 30k for just to get it to have drivability and dependability.
Old Mar 11, 2019 | 01:28 PM
drod's Avatar
drod
Service manager at my dealership told me I was lugging it and causing it to transfer oil...you would think they could come up with something better than that...
Old Mar 11, 2019 | 06:20 PM
Erilflynn's Avatar
Erilflynn
Unbelievable
Old Mar 11, 2019 | 08:50 PM
bikermikee's Avatar
bikermikee
I ordered the new clutch rod from Greg Williams last fall but didn't install it yet, too cold. But did I read on another thread their was a new variant of the fat clutch rod that had better contact points possibly? I messaged Greg a few days ago but never got a reply. Is he out of the clutch rod businesses now?
Old Mar 12, 2019 | 09:14 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by TriGeezer
I haven’t seen any description on why the “fat flat rode” works.
I’m thinking that since the issue is due to a lower pressure developing in the primary, it sucks from the transmission. Maybe some primaries leak a little pressure, and thereby didn’t develop enough vacuum to suck from the transmission. The flat side of the rod allows pressure equalization between the primary and transmission. They make it a bit thicker, because the stock rod does not have enough material thickness to create the needed flat, and it would also weaken it....
But, I could be wrong...I thought I was once...but I was mistaken. So now I am..
Well IMO, It's pressure variations stemming from the Slip-assist pressure plate changing clamping load plus possibly some additional pulses from mainshaft seal flex / leakage. Pulsations are caused by resulting forces the power stroke and slowing on compression for upstroke. Flywheels do not spin at a constant speed. That's why these bikes need compensators.
Anyway the thinner pushrod has enough clearance to allow the pulses to do their work. Fatter PR is 44% heaver and the clearance around the rod is decreased from about 38 thou to say 6 thou.. No sucking action gets through.
Old Mar 13, 2019 | 04:52 AM
tbob's Avatar
tbob
You should never speak to him again,you can't fix stupid.
Old Mar 13, 2019 | 06:50 AM
hellonewman's Avatar
hellonewman
And if you spin it at higher revs it'll sump
Sorry, couldn't resist.
Old Mar 13, 2019 | 12:48 PM
BAGRRR's Avatar
BAGRRR
6th Gear
Long story short..... It doesn't suck! LOL
Old Mar 14, 2019 | 06:32 AM
sweetglidez's Avatar
sweetglidez
New 19’ only 250 miles on it since I bought it last week but the fluids are staying put. 👍
Old Mar 14, 2019 | 07:05 AM
Mertoid's Avatar
Mertoid
Is the flat on the larger rod even necessary? Has it been tried without?
