Happy with a K&N air filter?
Old Apr 22, 2020 | 01:15 PM
RawmS's Avatar
RawmS
Stage III
Default K&N HD1717 mount screws issue...
Originally Posted by mjwebb
sounds like over tightening is the problem..should be able to just use a dab of medium blue loctite on the 3 bolts until they stop then turn just a tiny more..the center bolt from the OEM air cleaner cover with a dab of loctite will secure the whole assembly in place and nothing should come loose..I've never needed to use loctite on the 3 bolts for OEM filter nor does it instruct to..but maybe the K&N is weak and fragile
Just to be clear, I used the smallest of my three torque wrenches which uses measurements in in/lbs only (well, that and Nm as well, but I digress...). I phoned the K&N toll free number yesterday and they gave me an email address. I emailed and asked for a replacement filter and am still waiting for a reply. I also suggested they down the torque value in their instructions.
Yeah, the filter is definitely frail, especially when compared to the K&N air filter on my '96 Heritage Softail (all metal construction) which has lasted over one and a half decades! I will definitely treat the replacement delicately, if I ever get it.
BTW, I did find a noticeable increase in engine power when the K&N was on.
Old Apr 24, 2020 | 10:30 PM
PA1195's Avatar
PA1195
Locking compound can also do strange things to certain plastics like cause them to crack. HD specifically recommends "none" when their plastic rear cylinder heat baffles and some other parts are added that may be subject to contact. Removable Loctite Threadlocker 242 carries the warning "May attack some plastics."
See Limitations: https://dm.henkel-dam.com/is/content...-2018-04-09pdf
Reduce torque when using Loctite: https://www.cycleworld.com/2014/07/2...tening-torque/
Old Apr 25, 2020 | 09:43 AM
New Lenox Jim's Avatar
New Lenox Jim
There is no magic! K&N air filters do flow more air, at the expense of allowing more injested dirt. It's probably not an issue for most street riders who ride on paved roads, but I want my air cleaner to stop as much as possible. If you look at used oil analysis, when you see high silica levels, almost always an oiled cloth filter is used. Best example I've seen is an air cleaner comparison by PROJECT FARM (YouTube). He uses sifted flower to to see how much contamination gets through 4 different filters. K&N is a joke.
Old May 6, 2020 | 04:49 AM
RawmS's Avatar
RawmS
Stage III
Hey! Got my replacement K&N Air Filter last week. No charge to me. Thank you K&N. Put it on hand tight with a screw driver handle (spinner) and it works like a charm. The thing really does make a difference. As to it letting in to much dust: well, I live and ride in the Pacific North Wet Coast so dust isn't a major problem. My '96 Heritage has had a K&N Air Filter on it for almost two decades, over 200,000Km, and it still runs great!
Old May 6, 2020 | 06:24 AM
OldMike's Avatar
OldMike
It seems to me that stuff gets broken and screws get snapped more often when a torque wrench is used.
I use a torque wrench when I feel it is a critical fastener and usually use blue Locktite a lot. Maybe after 50+ years of doing this you get a feel.
painey
Milwaukee Eight (M8)
Jul 5, 2021 09:32 AM
Gibler77
106
Oct 24, 2019 10:10 PM
tkuligowski
2014-2024 Touring Models
21
Aug 12, 2017 03:36 PM
ravsta
Oct 28, 2014 10:24 AM
05wideglide
Apr 28, 2005 08:08 AM
