"SUMPING" needs explained
Old Feb 9, 2019 | 05:14 AM
Cazador's Avatar
Cazador
Member
Originally Posted by mjwebb
I read an article that stated "most accidents happen within 1/4 mile from your home", so I moved.
I park mine at a friend's house and walk from there. Maybe I should move? It would cut down on all that walking.
I have heard that auto pedestrian accidents are on the rise. Think I will call that realtor.
Old Feb 9, 2019 | 05:40 AM
Oz Dan's Avatar
Oz Dan
fn funny cheers!
Old Feb 9, 2019 | 07:26 AM
KrustyKush's Avatar
KrustyKush
Originally Posted by Kaution321
I hear as long as you cruise and ride it below 4k rpm and no hard riding lower risk of sumping. It all depends on your riding style if I knew you had to baby the M8 motor I probably would've waited for a fix before buying one.
Nonsense. I don't baby mine. It runs and runs. But if this was true, then best thing to do would be to run it hard and see if it will sump. If it does, take it for repair before the warranty runs out. Don't baby it, just ride it the way you do.
Old Feb 9, 2019 | 08:18 AM
hrdtail78's Avatar
hrdtail78
Originally Posted by 58jdn58@gmail.com
Hi guys. As an owner of a 2018 softie, AND avid forum reader, I don't understand SUMPING. No mechanic either! Lol. How does oil migrating from the tranny make the engine blow up? I have this mindset, that, the engine oil pan/ crankcase is a separate system from the other two(primary, tranny) and those egually as separate. I can possibly see tranny oil getting into the primary from a bad seal or something maybe, but that would result in an overfull primary and a dry unlubed tranny. Both bad. But how in the world would that time up an engine?
Sorry for being an idiot, but??? Lol.
You will get a lot of smart *** because most people have no idea why oil is migrating from a vented transmission case into a non vented primary case. The fox's have all been bandaids because it's hard to address the actual problem if you don't know what it is.
Old Feb 9, 2019 | 08:34 AM
lp's Avatar
lp
On a serious note and cut to the chase - Transmission oil traveling to the primary is a separate and different issue than engine sumping. You've combined two entirely different issues.
Old Feb 9, 2019 | 09:01 AM
skid_pimp's Avatar
skid_pimp
Come on man, read some of the other threads on this subject first. But so you are aware, you are correct the 3 holes for oil (sump, trans, and primary) should indeed be separate. But in some instances the trans is transferring to the primary, this is completely separate of the sumping issue.
The sump in most engines is at the bottom of the engine, and is more commonly known as the "oil pan". In some cars and motorcycles, such as ours, we have what is called a dry sump, which in a nutshell means the "oil pan" is relocated elsewhere than the bottom of the engine; among other things allowing the engine to sit lower to the ground to keep the center of gravity lower and more favorable. There are other benefits FYI, but in a nutshell the bottom of the engine is kept clear of excess oil by the oil pump that pushes the oil to the oil tank, at the same time as it pulls oil from the tank to give to the rest of the engine. In the cases where these bikes "sump" it means for whatever reason the oil is pooling in the bottom of the crankcase where there is not enough space for it to be pooled up without being in the way. Therefor it is getting hot and frothy from the crank whipping around and is causing interference, robbing power, and causing damage. There is more to it but that is the down and dirty.
Old Feb 9, 2019 | 01:06 PM
Super Glidester's Avatar
Super Glidester
Well as long as "Humping" doesnt need to be explained.....
Old Feb 9, 2019 | 01:20 PM
Kaution321's Avatar
Kaution321
😂 too funny.
Old Feb 9, 2019 | 01:28 PM
Oz Dan's Avatar
Oz Dan
I'll be selling mines one lucky buyer can own an M8. I dont have time to deal with figuring out whether M8's are still prone to sumping after three model years or susceptible whatever other transfer issues that could leave me stranded in the middle of a road trip. No rebuttals needed be glad that a used M8 will be posted for sale soon for those looking to get one.
only viable option - no time to lose.....lol
Old Feb 9, 2019 | 02:49 PM
Superdog3:16's Avatar
Superdog3:16
THANK YOU! That's exactly what I was asking.
