124" new build thread
Old Mar 2, 2019 | 10:15 AM
yobtaf103's Avatar
yobtaf103
Originally Posted by DRBUICK
The fuel moto level A heads are ported by ward I was told. I have a 130 inch 11.75 to 1 fully ported ward heads and intake a D&D 2 into1 TTS 250 cam mine made 143hp and tq with the Tman 234 cam made 147 hp and 132 tq. I have said for years Fuel Moto's numbers are high as a kite
Hi Doc, do you think there's a point where you've gone beyond the billet cat?
Just watched the HD cool Springs (117) cam/pipe test, interesting Billet cat v Khromewerks with that comp cam
Old Mar 2, 2019 | 10:27 AM
DRBUICK's Avatar
DRBUICK
Star racing still uses this pipe on his builds bigger than mine
Old Mar 2, 2019 | 02:00 PM
FLSTF's Avatar
FLSTF
Mine, not started build yet
S&S 124" BB @ 11:1
SE 64mm tb ( not ported )
5.5 SE inj
Stock heads
S&S 475g cam /lifters
S&S oil pump/camplate, (already fitted)
FM 2-1-2 header (not XXX)
FM outlaw slip-ons
AIM SDR /SE 1275 springs/stock plates
PVision/dyno tune
not sure what to expect as only seen this with a Bassani 2-1, lets just say result was exceptional, would be stoaked with 10/10 less
Mine will be similar.
S&S 124" bb kit
SE 64mm (intake ported by Ward)
5.5 SE injectors
Stock heads
S&S 475 chain drive
S&S lifters & pushrods
Feuling oil pump & camplate
D&D billet cat
Powervision dyno tune
Clutch? (possibly Rekluse)
Am interested in seeing OP's final results as well as yours. Will be an interesting comparison between the three.
Old Mar 2, 2019 | 07:12 PM
Monkeypuncher's Avatar
Monkeypuncher
What was everyone’s baseline run? My 114 did 94hp and 121 tq. with only a Bassani road rage pipe, otherwise, stock M8. Going with the 128 build, will post details and results.
Old Mar 3, 2019 | 11:49 PM
Apollo's Avatar
Apollo
Originally Posted by Carlos3621
new build for comparison sake:
S&S 124" BB kit @ 11:1
Ward ported SE 64MM throttle body and intake
5.5 SE injectors
Fuel Moto Level A ported heads
Fullsac headers
Fuel Moto Outlaw slip on's
Woods M8-408 cam and Woods lifters
HD latest oil pump and bulletin Seal kit
AIM SDR clutch
TTS tuner Dyno tuned
will post results within 1-2 weeks,
interested to see results as compared to the Fuel Moto builds advertised
Fuel Moto advertises around 145/145 for this setup, they advertise 150/150 using their XXX 2" stepped headers.
My builder claims more like 130/130 ,( I think he is being conservative.)
any guess as to what results will be??
What AIM lock up clutch did you go with and what's the torque rating for that AIM clutch?
Old Mar 4, 2019 | 09:55 AM
Carlos3621's Avatar
Carlos3621
I went with the AIM SDR clutch with the S.E. 1275NM springs,
if it slips, then I have the AIM Springs that will hold up to 160, when used with the spring shims.
Old Mar 4, 2019 | 10:45 AM
yobtaf103's Avatar
yobtaf103
Whats the deck height coming in at, the supplied S&S gaskets measure base 0.014" head 0.030" i have
just wonder if it's close enough to the 11-1 comp
Old Mar 4, 2019 | 02:20 PM
Carlos3621's Avatar
Carlos3621
Good question, but I'm not doing the work (no time).
Am not too worried about the deck height, because I'm not chasing numbers, although I am hoping it's around 140/140 with a tabletop tq curve.
I have read of the S&S kits with varying deck height, but I would rather leave the cylinders be and not have to machine them at this time.
Maybe on the next build I will decide to balance and blue print the damn thing...
Old Mar 5, 2019 | 01:17 AM
yobtaf103's Avatar
yobtaf103
Got some confirmation in the other 124 thread ,S&S have it covered pretty much with the supplied gaskets to give 11-1 with about 0.015" in the hole
Old Mar 5, 2019 | 09:04 AM
Carlos3621's Avatar
Carlos3621
Yes,
this makes sense, their kits were initially advertised @ 10.5:1
now, they are selling them advertised @ 11:1 , I called S&S directly to confirm this...
they must have made some adjustments to the base gasket and head gasket thickness....
