Oil Level .
Old Mar 28, 2019 | 06:43 AM
  #31
Gead's Avatar
Gead
[QUOTE = BrandonSmith; 18139153] O frio é perfeito. Quente é um pouco baixo, mas năo o suficiente para se preocupar. Minha suposiçăo é que a sua verificaçăo a quente năo era realmente a temperatura operacional completa, e digo isso porque a verificaçăo a quente deve mostrar o nível quase o dobro do nível da verificaçăo a frio. Geralmente, săo necessários 20 a 30 minutos de conduçăo para atingir a temperatura operacional total (além disso, năo pare de funcionar uma bicicleta refrigerada a ar por mais de 5 a 10 minutos).
Năo sei por que seu óleo é vermelho. Qual óleo vocę está usando? [/ QUOTE]Motul 7100 20W50 I've always used this oil on my bikes, the manufacturer says that this oil is very stable and does not have much hot or cold volume variation, was it placed 3.8L correct?
Old Mar 28, 2019 | 08:18 AM
  #32
Phil13's Avatar
Phil13
Gead, do you have a relative, named Bob RR by any chance?
Old Mar 28, 2019 | 09:24 AM
  #33
Gead's Avatar
Gead
[QUOTE = Phil13; 18139640] Gead, vocę tem um parente chamado Bob RR por acaso? [/ QUOTE]
Friend I am Gead Klein and in the Klein Family I do not know any Bob RR.
Old Mar 28, 2019 | 12:01 PM
  #34
kap1's Avatar
kap1
Originally Posted by Long time rider
Adding oil to a Harley is not brain surgery people. First, RTFM. Then whatever you do, do not overthink what you just read. Do it by the numbers if you have to. If you still can not figure it out you should probably sell the motorcycle and get a bicycle that does not need oil.
Of course, there is that pesky chain lube thing which could be good for a couple of pages.
Old Mar 28, 2019 | 12:31 PM
  #35
mjwebb's Avatar
mjwebb
so I added fluid, attached a pic, does this appear to be the correct amount of fluid in the bulb?
Old Mar 28, 2019 | 12:32 PM
  #36
Mchad's Avatar
Mchad
What does the manual say?
Old Mar 28, 2019 | 12:36 PM
  #37
mjwebb's Avatar
mjwebb
no more than 1/2 Full Cold, but I pulled this out after driving around the block 50 times using the turn signal to get it to operating temp
Old Mar 28, 2019 | 01:23 PM
  #38
Gead's Avatar
Gead
thank you friends for helping me, complex service this that in months I asked hundreds of questions to various experts and always got different answers, I did within the logic that I found the most correct, today I finished my stage 1 and I will rotate ....,,
Old Mar 30, 2019 | 12:31 AM
  #39
Agoober's Avatar
Agoober
Measure the oil the same way every time through the same process every time. I have two methods hot while riding when I make my first stop or after a ride idling it upright for around two minutes before I stop it and checking when it's been cold for a few hours.These things measure all over the place , I genuinely believe that's why some people have issues.
Peace.
Old Apr 1, 2019 | 12:41 AM
  #40
azgrumbles's Avatar
azgrumbles
What you don’t want, is to see the hot level halfway up the “check upright” blocks when it’s on the jiffy stand. This happened to me after my last dealer service. I sucked out a pint of oil and now it’s good. SMH
