Front brake not engaging
Old Apr 28, 2019 | 09:01 PM
KrustyKush's Avatar
KrustyKush
I was surprised to learn that the linked system on the my 2018, and presumably yours, too, is not hydraulically linked, as what I'm used to with Hondas. The "system" links electronically. Mine works great.
However, some time back I started feeling a vibration in my front end when apply front brake alone to slow down from, say, 80 mph to take a freeway exit. I thought it was warped rotors. I took the bike to dealer shop, and they said my ABS module was toast, and replaced it. Post-remove and replace of ABS module, the vibration was still there.
Then, I found out that if I applied my front AND rear brakes at approximately the same time, there was no vibration. Since then, I've developed the habit of using both front and rears most all the time, whereas before I had a habit of using almost exclusively the front brake. Leftover habit from my Japanese sport bike days.
I understand that use of both fronts and rears offers the best braking performance, and for whatever strange reason, it also makes the brakes a lot smoother. Can't explain why.
Old Apr 28, 2019 | 09:20 PM
CSMHOG's Avatar
CSMHOG
Originally Posted by nobodyknowsme
What I failed to mention that is noteworthy is that I swapped the front wheel for a 21". This supposedly had an ABS bearing but shortly after putting the wheel on I started having ABS issues, warning light on and a short time ago they would lock up if I hit the panic button, like had to jump on them hard.
I made an appointment to get the bearing swapped at the friendly dealership next weekend. Just hope I don't regret that decision as my faith in dealerships is not all that great.
That is a pretty key piece of information to leave out. Let us know how this works out when the correct bearing is installed. BTW, the ABS bearing is slightly wider than the Non ABS bearing, hope your hub will support the correct bearing. Maybe a different sized spacer will make things right? Good luck.
Old Apr 30, 2019 | 04:58 PM
nobodyknowsme's Avatar
nobodyknowsme
This is interesting as I also have noticed what feels like a warped front rotor. Maybe at least a part of this will be covered under warranty. Yeah, right...
Old May 1, 2019 | 01:12 PM
KrustyKush's Avatar
KrustyKush
When I took my bike to the dealer for the braking vibration, I expected them to blame warped rotors and either replace them or tell me they aren't covered under warranty, which would have been fine with me. But ten minutes after riding my bike into the shop, and presumably plugging in to the 'puter, the tech came back saying the ABS module was "throwing codes" and was probably defective. MoCo agreed and shipped out a new ABS module.
I had my doubts, because I had never had any codes show up, and told him so. In any case, replacing the ABS module did not affect the vibration. I was resigned to new rotors. Then, I discovered how smooth the brakes are when applying both front and rear brake levers simultaneously. It really smoothed things out.
Old May 3, 2019 | 07:42 PM
nobodyknowsme
Thanks and I will be mentioning the ABS module when I am there in the morning.
Old May 5, 2019 | 08:49 AM
nobodyknowsme
Turns out the ABS module needs replaced but had to be ordered. There is also an 02 sensor ordered so I know where I will be spending a couple hours next Saturday. It just leaves an unsettling feeling riding a bike with questionable brakes. Hopefully this time next week all will be back to normal.
Old May 5, 2019 | 10:19 AM
KrustyKush's Avatar
KrustyKush
Interesting. I never was aware of any problem with my brakes, apart from the appearance of the braking vibration, and replacement of the ABS module had no effect on the vibration. I never had a fault light come on, and never had any hint of brake malfunction. But the dealer and HD insisted on replacing the ABS module. I had to wait about five days for the module to arrive, during which the bike sat at the dealer. Then another five days for them to get it stitched up and test rode, because it was rainy season and apparently they don't test ride in the rain. When I got my bike back, there were about 30 miles of test ride on it so I know they put it through its paces.
As for the vibration I feel, it is still there, but only if I brake from a high speed using front brake only. brake from low speeds has no vibration. As long as I apply both front lever and foot lever at approximately the same time (I probably tend to hit the rear just ahead of the front) there is almost no vibration at all, and the bike hauls to a good clean stop. I'm glad I broke this bad habit I had of using mostly front brake only. I cannot explain why the brakes are so much smoother with both levers used simultaneously, but there is no doubt the bike stops better, smoother, more under control with both levers used all the time. Except, of course, low speed u-turns where you want to stay off the front lever.
m50
Dec 11, 2017 10:12 AM
Trek
Jul 5, 2016 06:39 PM
junglejoe
2014-2024 Touring Models
43
Sep 21, 2014 05:02 PM
SquidHead
May 3, 2013 01:26 PM
JoeHat
Wheels/Tires
Feb 24, 2011 10:49 AM
