Stage 1, Decat and Warranty
Old Jul 11, 2019 | 12:32 PM
mikes300's Avatar
mikes300
Originally Posted by strych9
You are wrong. The dealer has to report it in order for the MoCo to void the warranty. I happen to know an '18 RGS owner that decatted his stock header and has had his bike to the dealer for warranty work. They haven't said a word about it, and HD is none the wiser.
There is no instant warranty voiding going on...some dealers are either naive or STILL looking the other way for stuff like this. Here in the great state of Nebraska, we have no EPA emission testing, so it's fairly easy to get away with things. Hence, COULD is still the operative word.
well yes I suppose he could get lucky.
Old Jul 11, 2019 | 01:21 PM
RCUltra's Avatar
RCUltra
Originally Posted by 04ctd
so....a Trike is a whole different monster, because the air behind your right thigh does not circulate, my wife got second degree burns & blisters on her trike.
the trick is to Mod the stock air Box:
https://www.hdforums.com/forum/touri...r-housing.html
we did the Air box mod, and the bike was AWESOME to ride, nice & cool with air flow behind the right leg.
then, we spent ~$1000 and did the Stage 1, removed the CAT, with a HD Air cleaner, HD pipes, HD tuner (SEPST?)
and the bike is HOTTER with the Stage 1, than it was with the Modified Air box, because now, the round style air cleaner blocks the air from flowing around the inside of your right leg,
and the rear trike fender blocks the air flow out of that area.
does the bike RUN better? yes!
does it still cause blisters on the rear of your thigh? almost it's very uncomfortable with the big round air cleaner.
i even bought a longer bolt & spaced out the Evo style cover, and it's still HOT behind your thigh.
DK customs will jump in here, and he has done a TON of Mods on Trikes, some are $459 each (oil filter re-locate & oil cooler),
you should definitely try the modified air box before you try those, just to enjoy riding the bike.
Looks like I have a project tonight. Thank for the tip on the air box. Looks like a simple mod with no downside. I've also read about the DK tank lifts. I wonder if they help to increase flow. At the end of the day, if I can leave the drive train stock and get rid of some of the heat, I'd be a happy camper.
Question...Could you put a high flow filter in your modded air box?
Old Jul 12, 2019 | 06:51 AM
jmeyer58's Avatar
jmeyer58
A couple of quick notes,
decatting the pipe will make the bike a little louder but will not show up when the dealer plugs in their scan tool. The dealer would have to remove the muffler and look into the pipe to see that you decatted the pipe. The O2 sensors are before the cat so the computer has no way of knowing that you removed the cat. If you leave the mufflers and intake stock there is no reason to add a tune.
If you use an aftermarket tuner as soon as the bike is plugged in the Harley system voids your power train warranty. John Maxwell has a good video on YouTube explaining this.
Old Jul 12, 2019 | 08:19 AM
rossn2's Avatar
rossn2
This is not correct, the dealer doesn't report anything to MoCo. The minute the TECH hooks up the Scan Tool, the information is sent directly to MoCo, if there's anything different within the ECM factory settings, and you have anything that comprises EPA rules, MoCo voids your power train warranty and they will not even tell the customer. I took my bike in for the Clutch recall and dang TECH hooked up the Scan Tool without ever informing me.
It just happened on my 2017 RCU, with Cobra Exhaust system, Stage 1 Aircleaner, and Stage 1 download (dealer used a PowerVision tuner and did all the work back in Aug 2017). MoCo voided my powertrain warranty. They wouldn't even cover the oil transfer issue, which has been known since SEP 2017.
And, oh, take your NON-Stock bike to a dealer in California for an oil change, when you're on a road trip...they throw you off the property due to excessive fines by the State/EPA.
Old Jul 13, 2019 | 02:31 PM
alarmdoug's Avatar
alarmdoug
The whole decat thing is silly in some respects.
HD is not the EPA police and the average mechanic and dealer could care less about a cat, simple as that. They want your business!
Yes of course anyone will know it was removed because you will smell the exhaust fumes.
Last I can remember the EPA does not require any motor vehicle brought in for service to have a mandatory catalytic converter inspection, no matter if it's a boat, car, truck or bike... Really talking silly here, as long as your warranty claim is unrelated to cat removal.
Old Jul 13, 2019 | 02:45 PM
teedoff65's Avatar
teedoff65
Not sure about your state, but many states, mine included, have for many years required exhaust emissions tests when a motor vehicle gets inspected. So while inspection stations or mechanics are not the EPA police they have to inspect vehicles, cars or bikes, according the inspection guidelines set forth. Plain and simple.
That said, I don't think HD actually does do emission tests in the manner with which cars are performed. If they did, bikes with decatted headers would fail automatically and the dealer would have NO say in it.
Old Jul 13, 2019 | 03:26 PM
RCUltra's Avatar
RCUltra
Here in TN it goes by county. Nashville has emissions testing. On computer controlled cars they look for an engine light. If they see one, they plug in and make sure it is not emissions related. They sniff older cars. Not sure about bikes. Wife wouldn’t ride amongst the crazy Nashville drivers, so we didn’t get back into bikes until moving to West TN, which has no emissions testing.
Old Jul 13, 2019 | 06:06 PM
RCUltra's Avatar
RCUltra
So what if you install an S&S 50 state complete system? What HD wants us to believe is that they void the warranty because You are no longer emissions legal...and that only their parts installed by a dealer can get you there while being emissions legal.
what if you can be emissions legal without using their parts and labor? Would this be an opportunity to remind the of magnuson-moss?
Actually, as long as the bike meets the emissions standards where it is registered, they should not be able to void the warranty. Your proof of compliance is your plates. I think EPA excuse is a convenient way to force us down their road. If they made better stuff and decent prices, they wouldn’t have to do that.
Old Jul 13, 2019 | 07:58 PM
mikes300's Avatar
mikes300
That’s new one in me, and I have lived in CA my entire life. Never heard of such a thing, we don’t even have any kind of bike inspection program, only cars. No clue what fines those would be.
Old Jul 13, 2019 | 08:01 PM
mikes300's Avatar
mikes300
This is not true, it’s only the tuner that’s the issue, they can’t void anything if it’s been 50, state legal certified. And that’s only 2017 and up bikes
