All,
I plan to look at a 2020 Ultra Limited and 2020 Indian Roadmaster for my next bike (maybe even a Goldwing (thought I would never say that)).
For the M8 motor:
1. Any information on mileage that the M8 plastic cam chain tensioner needs to be replaced?
2. Any information if the M8 crank is true? I have been told the M8 still uses a press fit crank as compared to Indian using a one piece machined crank.
I am coming off owning two TC 88 HDs. I am still feeling the sting of the faulty design for the cam chain tensioners on the TC 88 motor. It has pushed HD to the bottom of my list for bikes to consider, so is there redemption for HD with the M8 motor? Did HD get it right this time?
I've had no more trouble with my 2018 FLTRU than I had with any of the four Goldwings I owned.
One thing, though: For best reliability, keep the bike stock. Don't fiddle with the motor or exhaust, or the airbox. Just leave it stock, the same way you'd leave a Goldwing stock. It is easy to see that most of the troubles people have with Harleys follows their fooling around with the engines, to make them more powerful, or sound different.
The M8 makes plenty of power in stock form. Just like a Goldwing does.
A properly-manufactured cam tensioner should last the life of the engine. The TC engines had low-grade tensioners in them. There's some owner on the forums here with over 100K on his M8 bike, and I don't think he ever had to fix much of anything throughout his ownership.
I agree with this, the 114's have plenty of power. Heck, the 107s were good enough so that I could save the $2K for a stage 1. Just add slip-ons and go.
Crank not a problem, tensioner shoes havent been a problem since they switched to hydraulic in 07 on the touring bikes.
Originally Posted by KrustyKush
I think HD got it right with the M8.
Ther good thing also about the cam tensioner on an M8 is that there is only 1 and you don't have to RnR the cam plate to replace. 2 hour job? I don't think there have been any recorded failures yet here.
Regarding the crank being true question, the spec in the HD manual is so huge that a crank thats junk by others standards is okay by Harley. IIRC the spec is over .015" and its still okay! Uh huh.....
I think the reality is any of the cranks post timkin twinkie are not great but they do the job well enough.
