Engine temps
I rode to work this morning, about 20 Miles of flat freeway riding at 75mph, it was 35 degrees this morning and the lower vents were closed. My engine temp got up to 310 degrees and the cylinder head temp was around 330 degrees before they kinda stabilized there.
On the way home, same route, 50-55 degrees this time, with the vents open. This time the temps got to about 290 Engine and 320 At the head.
That’s quite a bit warmer than I thought they would be, the bike runs awesome when it’s cooler out. I wish I had done some testing before I installed the lowers, maybe another day, they’re staying on till summer At least.
Also, does anyone know if the PV can display oil temp and pressure? I can’t seem to find the parameters on the list of ones it can display.
here is a thread if you want to see more on temps...
