117 SE CVO Question
SE HEADS? What's the deal with SE heads? How are they different and what makes them better than the basic heads?
Intake? Does the 117 already have the 64mm intake?
SE 117 CVO cam? What is it exactly? Is it different than say the 114?
What is it similar to, both MoCo and aftermarket?
Will a stock 117 respond well to just a cam upgrade and professional dynotune and a TTS (say leaving the stock exhaust)?
Cam Tools...Will the cam tools for a twin cam work on a M8? I have the full set of cam tools from the job on a 2014 FLHTK...
Lastly, How much did MoCo leave on the table with the 117 if anything?
Yes, it will respond well to a cam upgrade and dynotune. Removing the cat will help slightly, but not significantly. Mostly cuts down on heat.
114 they list as 123 ft lbs of torque at 3000 rpms
117 they list as 125 ft lbs of torque at 3500 rpms
the 114 has higher compression, but guessing the 117 has a few more HP ..makes me wonder if there's any real world seat of the pants difference and they only replaced the 114 with the 117 in CVOs to show they are bigger and better for the most expensive bike they offer..I'm probably missing little details that make it better but what are they...???
SE Heads have different port design, larger valves and different valve springs
NO
The 107 and 114 all use the same camshaft the CVO 117 has a upgrades cam
Yes
Depends on who's tools as the cam bearing itself is the same as the TC bearing
