S&S 475 gear drive cam install
Old Dec 22, 2019 | 06:47 PM
Adams17RG's Avatar
Adams17RG
Default S&S 475 gear drive cam install
Preparing to install the gear drive S&S 475 cam on a M8 and I noticed the S&S instructions don't list a cam spacer behind the cam gear. Is there no reason to check for alignment between the upper and lower sprockets as you would with a chain drive?
Old Dec 22, 2019 | 08:04 PM
RK14SGS's Avatar
RK14SGS
yes, you need to check!
Old Dec 23, 2019 | 05:55 AM
$tonecold's Avatar
$tonecold
The reason for the spacers on the chain drive is to align the gears to make sure the chain isn't in a bind. More than .010" is too much.
If your gears on a gear drive are not lined up exactly, nothing will be in a bind. If you assemble it and find that it has a lot of offset, I guess you could shim it, but it probably isn't necessary.
Old Dec 23, 2019 | 02:14 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Remember you can place the crank gear in place, then hold the cam gear and check it before you tighten the cam bolt. As said, a little misalignment in the gear drive doesn't bother it much unlike a chain drive.
Old Dec 23, 2019 | 02:23 PM
Adams17RG's Avatar
Adams17RG
Thanks guys. I figured as much. Just found it odd that S&S does not mention checking sprocket alignment.
EarlB
Oct 19, 2019 09:53 AM
byersmtrco
2018+ Softail Models
Jul 30, 2019 09:31 AM
Rednosedherring
Apr 26, 2014 10:06 AM
rickb
Jan 23, 2012 07:49 PM
bikerbehaviorist
Exhaust System Topics
29
Feb 26, 2006 03:26 PM
