Dragos offers a different crank for the M8 with a dual Timken setup. That said, I don’t think you can do the Timken conversion on the OE crank but I’m not entirely sure.
Dragos offers a different crank for the M8 with a dual Timken setup. That said, I dont think you can do the Timken conversion on the OE crank but Im not entirely sure.
Dual Timken? You mean one on each side of the crankshaft?
Call Darkhorse and talk to them. They know all things about Harley bottom ends. Plenty here have put 128’s on stock cranks/bearings though (me included). Unless you beat the living hell out of your motors you’re likely fine staying stock. However, I expect nothing beats the smoothness and piece of mind blueprinted crank. Last I saw it’s about $1800 for a soup to nuts rebuild including a timkim from Darkhorse.
I’ve got .005 runout (edit: on the pinion shaft) on my Dyna which while well within spec, isn’t fantastic so I’ve been thinking about it.
Only problem is it’s about a 5 week turnaround, which is tough to swallow.
The M8n has a 1.75 inch crank pin where the TCs only had a 1.671. The M8s seem to be a bit stronger. I guess you could steel plug the ends if you needed a little bit more.. (DH trick)
