Electrical problem help
Old Mar 25, 2020 | 09:04 AM
berniemc's Avatar
berniemc
Default Electrical problem help
On my 2018 Road glide ,right rear turn/run /brake light.Light works,turn signal works but when brake is applied the light goes out.No codes wiring is connected..I am stumped.I changed bulbs and still same.Have the wrap around saddlebag lights and they both work correctly.Thanks for any help.;
Old Mar 25, 2020 | 09:19 AM
mjwebb's Avatar
mjwebb
hmmm..could post this in the electrical issues forum if nobody solves it here quickly..probably something simple is my guess..might just disconnect and remove and reinstall..kind of like rebooting pc
Old Mar 25, 2020 | 10:16 AM
Keithhu's Avatar
Keithhu
Likely still under warranty, make the dealer fix it.
Old Mar 25, 2020 | 10:58 AM
Robtarra39's Avatar
Robtarra39
Did you check the brake light switches
Old Mar 25, 2020 | 12:34 PM
Crabchuck's Avatar
Crabchuck
I have a 2018 service manual. First thing I noticed is in figure A-24 "Rear Lighting". There's a facia/converter module shown between the lights and the harness. No details on what this module actually does. So, if I were to troubleshoot this, I'd disconnect the main harness from the module and break out the volt meter. Based on the diagram, the connector should have 12 positions. Positions 2, 8-11 should be empty. Pin1 is black, pin 12 is R/Y.
****I'm making an assumption here that the system doesn't stop working because it can detect it's disconnected.
1) Check pins 1 & 7 for ground.
2) Pin 12, R/Y for 12V with key power on (power from BCM).
3) Pin 3, Bl/Br, should flash 12V with front right turn signal.
4) Pin 4, Bl/V, should flash 12V with front left turn signal.
5) Pin 5, Bl/R, should go to 12V with brake applied.
6) Pin 6 Blue, should be 12V constant. This is the tail/running light.
If I understood right, the right signal light is on with the running light, and goes bright for the turn signal. But when you hit the brake, it goes out completely. What if you have the right turn signal on AND the brake? Does it still flash? I wouldn't think it would be the BCM since all the functions seem to work independently. Right now, that module seems very suspect. And I agree with the advice about warranty. As long as you didn't buy your '18 more than 2 years ago.
Old Mar 25, 2020 | 02:45 PM
berniemc's Avatar
berniemc
Warranty was out in November.I will check it out and thanks for the advice.
Old Mar 26, 2020 | 06:06 AM
Hawg Runner's Avatar
Hawg Runner
Bad ground on that light?
Old Mar 26, 2020 | 06:36 AM
Mchad's Avatar
Mchad
When did it start? Prior to it happening did anything change? I.e, saddlebag light installed? First thing i’d do is remove the saddlebag light module from the harness and see if it resolves. As I recall it’s just two plugs.
Old Mar 26, 2020 | 08:59 AM
Hd589's Avatar
Hd589
+1
if it’s a dual filament bulb which i believe it is it has to be inserted correctly or else it will not work as the polarity for the second filament is grounded instead.
remove the bulb and try installing the other way.
Old Mar 26, 2020 | 09:29 AM
Mchad's Avatar
Mchad
Originally Posted by Hd589
+1
Aren't 1157 bulbs keyed? i.e. can only install one way? I guess one could force it, but thats just silly.
