M8 sump?
Old May 1, 2020 | 11:15 AM
oldsoldier181's Avatar
oldsoldier181
As I recall, it wasnt technically sumping, but rather oil transfer, due to a pressure build up. The addition of the vent hose stopped that, and there have been very few, if any, cases since that fix. The sumping issue, as I recall reading, primarily had to do with when people went to stage II, or III, and it was a part failure that caused it. I am certainly no expert, but that is, essentially, what I recall reading.
Old May 1, 2020 | 11:21 AM
Keithhu's Avatar
Keithhu
I had 3 stock 2017 107 FLTRU engines replaced under warranty. All parts failures?
Old May 2, 2020 | 03:27 AM
KrustyKush's Avatar
KrustyKush
Why not? It is easier to suppose three consecutive engine deaths by parts failures than to try to figure out why a hundred thousand other motorcycles with the same exact identical engines run just fine.
In my 71 years of using machines and fixing them, I have plenty of times got two or three consecutive parts that were bad out of the box. When I was working as a tech on postal automation machinery, I saw plenty of weird things come out of the parts rooms, things that were hard to explain, odd coincidences that made us scratch heads and wonder at the wonder of it all.
Old May 2, 2020 | 10:34 AM
Fullbore55's Avatar
Fullbore55
Originally Posted by SS Twin
,,,. Ii is Stage 1 with Wood 22X cam
Wouldn’t this be a stage II?
Old May 2, 2020 | 01:26 PM
SS Twin's Avatar
SS Twin
I thought so too, till some "expert" told me a while ago that cam only on a Stage 1 tune was still sage 1. According to him, Stage 2 and above involve displacement, head work, machining, etc. in greater amounts as you go up the stage #. In any case, 1 or 2, I love mine just the way it is!!!
Old May 2, 2020 | 03:16 PM
MTBIG G's Avatar
MTBIG G
Couldn't agree more with the last statement. These M8s are excellent machines.
Harley "stage" terminology has been around a long time and has been used by HD as well as many aftermarket companies. The idea is that you can build a little at time with each stage building on the previous. Anyway, just to clarify in my own laymens tems:
Stage 1 = pipes, a/c and tune
Stage 2 = Stage 1 plus cam
Stage 3 = Stage 1 plus cam and displacement
Stage 4 = Stage 3 (basically) plus heads
CarterSlade
Engine Mechanical Topics
16
Aug 12, 2019 06:40 AM
Sharpie
Oil Archive (no new posts)
Mar 15, 2013 04:44 AM
ELAMARZ
Sep 12, 2006 10:58 PM
kaduku
Jul 12, 2006 04:09 AM
toddreber
Mar 9, 2006 07:50 PM
