Burning Oil Smell??????
Old Jul 10, 2006 | 04:38 PM
kaduku's Avatar
kaduku
Default Burning Oil Smell??????
I recently did a oil change to Mobil One V-Twin, now after riding around I get a burnt oil smell, bad enough to where my riding partner can smell it. When I get home I have to leave the garage door open to air out the smell. What could be the cause of this? Overfill?????
Old Jul 10, 2006 | 05:28 PM
Z's Avatar
Z
Default RE: Burning Oil Smell??????
Things that come to mind: spillage on pipes; overfillage; loose filler cap or drain plug allowing oil to blow onto hot surfaces; loose or improperly seated oil filter allowing oil to blow on hot surfaces.
Old Jul 10, 2006 | 05:36 PM
kaduku's Avatar
kaduku
Washed biked after oil change. No spills anywhere (muffler, engine), checked caps and plugs. Maybe overfillage!
Old Jul 10, 2006 | 05:56 PM
Original Junior's Avatar
Original Junior
From: The birthplace of our nation- Philadelphia proud!
I had the same issue for the first 1000 miles or so. No leaks and not overfilled. All looked good. I attribute it to me being so familar to the smells of my diesel truck that this is just unusual to my nose. After that first 1000 miles I didn't notice any longer.
Old Jul 11, 2006 | 12:09 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Check the engine oil when it's hot.......the dipstick don't lie. Spray around the filter area with brakekleen (when the bike is cold) and wash again.
Old Jul 11, 2006 | 01:25 AM
kaduku's Avatar
kaduku
I removed some oil today, rode around, then checked oil level again, showing about half and I can still smell oil, though not as bad as before. I will buy Brakekleen and try that.
Old Jul 11, 2006 | 01:39 AM
wlbowers's Avatar
wlbowers
ORIGINAL: kaduku
I had the same problem with mine. It had dripped down behind the heat shields.
Like to have never got it cleaned out. Found some foaming simply green that did the trick.
Old Jul 11, 2006 | 09:56 PM
kman42oo's Avatar
kman42oo
if it's hot outside , you could be smelling the trany oil from the vent...
Old Jul 12, 2006 | 12:19 AM
dmanyeah's Avatar
dmanyeah
Stage IV
Check your rear cylinder housing towards the top and back. The gaskets are well know to go bad on these bikes and thats how mine started. I smelled oil and as time went on I started to get oil leak to the point where I could see it. You could be leaking a little and burining it off at this point. Keep an eye on that rear head.
Old Jul 12, 2006 | 04:09 AM
kaduku's Avatar
kaduku
Thank everyone. I am keeping an eye on all that you guys think is causing this. I rode again today, and can hardly smell it now, though there's still a hint of it.
hitman1267
Oct 29, 2014 08:06 AM
harleyglen
Sep 27, 2013 10:38 AM
rperk60
Oil Archive (no new posts)
Jul 29, 2013 04:57 PM
cvaria
Feb 25, 2013 09:37 PM
ord sgt
11
Oct 4, 2007 07:12 PM
