header pipe question
Old May 28, 2020 | 05:58 AM
cruisinmann's Avatar
cruisinmann
Originally Posted by ajcjr
So i have 4" rineharts (i swapped out the baffles) on my bike, stage 1 air cleaner and the pro street tuner. i was going with either the VH header or if i can get the rinehart one (unless someone has a better suggestion) but the dealer is telling me a need a different tuner to do the fuel map, is this true?
tuner i have : https://www.harley-davidson.com/stor...ance-tuner-kit
Thank you
In a stage 1 or 2 application the harley pipe is fine unless you're going over 130 hp don't waste your money on a different head pipe won't make any difference. Speaking of 2-1-2 pipes not 2-1
Old May 28, 2020 | 07:20 AM
ajcjr's Avatar
ajcjr
thanks
Old May 28, 2020 | 09:18 AM
SWFLGuy's Avatar
SWFLGuy
I have the rinehart header on my stage 2 107 and I am using the sepst and the add on tuner.
It runs just fine for me.
Old May 28, 2020 | 10:20 AM
ajcjr's Avatar
ajcjr
https://houseofharley.com/harley-dav...-41000445.html
this is what they are recommending i get. they want to use the vance and hines pipe with my rineharts.
Old May 28, 2020 | 10:22 AM
ajcjr's Avatar
ajcjr
Originally Posted by touchdown
so will changing the header pipe unless he uses screaming eagle headers.
dealer told me using the V&H pipe will not void my warranty and adding on a module from screaming eagle that monitors the 02 sensors
Old May 28, 2020 | 10:28 AM
Harleylife1's Avatar
Harleylife1
Id recommend the V&H for sure. Always had great experience with their stuff.
Old May 28, 2020 | 10:31 AM
ajcjr's Avatar
ajcjr
i guess its normal people use different slip ons and headers?
Old May 28, 2020 | 01:49 PM
$tonecold's Avatar
$tonecold
My question is, what are you trying to gain? If it is performance, I don't think you will see it. If anything, the Rineharts are pretty open with little back pressure. Going to a catless pipe might make the performance worse. If it is looks then it is a personal choice. If you are looking for more sound, you might get that, but as I said, it might cost some performance.
Old May 28, 2020 | 02:52 PM
davewear's Avatar
davewear
Reduction in heat is the only real difference going catless. A touch more volume.
Old May 28, 2020 | 08:54 PM
stevieb1973's Avatar
stevieb1973
I just installed fuel moto ac/dc air cleaner 2-1-2 headpipe, zippers 468 cam, and thundermax. I already had TAB zombie mufflers that dealership installed when new. All I can say is wow, this bike came to life and I love fuel moto and my bike. Good luck
