header pipe question
Old May 27, 2020 | 06:16 PM
ajcjr's Avatar
ajcjr
Default header pipe question
So i have 4" rineharts (i swapped out the baffles) on my bike, stage 1 air cleaner and the pro street tuner. i was going with either the VH header or if i can get the rinehart one (unless someone has a better suggestion) but the dealer is telling me a need a different tuner to do the fuel map, is this true?
tuner i have : https://www.harley-davidson.com/stor...ance-tuner-kit
Thank you
Old May 27, 2020 | 06:21 PM
h7009's Avatar
h7009
Just an opinion, I would just run the stock head pipe. Maybe a "better" tuner would be better, but as a Stage 1, it should run just fine. Just one guys opinion. Good luck, CSM-H
Old May 27, 2020 | 07:56 PM
OldMike's Avatar
OldMike
Thank you
Interesting, which tuner are they suggesting you need and why?
Old May 27, 2020 | 09:37 PM
ajcjr's Avatar
ajcjr
im trying to find out
Old May 27, 2020 | 10:12 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
1) SEPST tuner only tunes to Screamin Eagle parts configurations, and 2) a catless header would lie outside EPA regulations (the SEPST tuner stays within EPA standards).
Side note in case you are unaware. Using a different tuner than the SEPST will void your factory warranty instantly. There are a lot of threads about this and I don't want to turn your thread into one of those threads - just want you to know.
Old May 27, 2020 | 10:16 PM
touchdown's Avatar
touchdown
I have used V&H power duels, and Rush power duels header pipes they both preformed about the same. I liked the V&H for the fit and finish so I would go with the V&H myself, don't know nothing about the pro street tuner, I have always used power commander
Old May 27, 2020 | 10:19 PM
touchdown's Avatar
touchdown
so will changing the header pipe unless he uses screaming eagle headers.
Old May 27, 2020 | 10:54 PM
BrandonSmith
RE: warranty, yuuuup
Old May 28, 2020 | 03:54 AM
RedSlayer43's Avatar
RedSlayer43
It sounds like a ploy from the stealership to void out what you've got going on. I'd be interested to hear what they have to say... If the dealership tells you that you need a better tuner then why sell you the SEPST in the first place?
Old May 28, 2020 | 04:56 AM
Wmitz's Avatar
Wmitz
The hd tuner will work on hd parts, meaning with catalytic converter in place. To my knowledge, there are no maps available for aftermarket parts. Additionally the hd tuner does not have the capability to tune outside epa parameters. That means it is limited in the ve tables, afr, and timing. The aftermarket tuners go way beyond the epa, which are needed to tune a bike without a cat. Technically you could tune a bike with a hd tuner and an aftermarket pipe on, but it wouldn’t run that good, and you voided the warranty anyway so what is the point.
