header pipe question
Old May 28, 2020 | 08:57 PM
ajcjr's Avatar
ajcjr
im going to add the torquer cam from SE/HD as well. Might as well just do it and get some performance.
Old May 28, 2020 | 11:07 PM
RedSlayer43's Avatar
RedSlayer43
Originally Posted by $tonecold
My question is, what are you trying to gain? If it is performance, I don't think you will see it. If anything, the Rineharts are pretty open with little back pressure. Going to a catless pipe might make the performance worse. If it is looks then it is a personal choice. If you are looking for more sound, you might get that, but as I said, it might cost some performance.
I've heard that as well, that performance wise there are things that work really well, and things that sound great but don't provide the power.
Old May 28, 2020 | 11:22 PM
Gorion's Avatar
Gorion
Veteran: Coast Guard
4" pipes are too big for a small block chevy lol. The larger the diameter pipe, the slower the pulses move through the pipes making the scavenging of the exhaust gasses from the heads less efficient. When you only have 1 cylinder feeding a pipe you have fewer pulses, necessitating a smaller diameter pipe. this is why a 2 into 1 pipe makes more power. there is a negative pressure area behind a pulse when the pulse from another cylinder comes closer to the pulse (because it enters the pipe in half the time it takes for a second pulse from the same cylinder) it accelerates to fill that void. the extra vacuum then pulls more gasses from the head. The trick is to get the diameter just right and in the case of a 2 into 1 having the lengths just right so the pulses enter the single pipe at the right time so the spacing of the pulses is optimized. If the pipe is too small then back pressure occurs causing gasses to be trapped in the head. Back pressure is bad mmmmkay.
Old May 29, 2020 | 03:24 AM
Mofo67's Avatar
Mofo67
I have a friend with the stage 2 toque cam, Rinehart slim duals with 4” mufflers. He is using the tuners your dealership is suggesting. His bike runs great.
I ran the same stage 2 set up but with the S&S El Dorado exhaust on 2 M8s with really good results.
Lentini93
Jun 26, 2015 07:51 PM
SH_01FXDWG
May 24, 2015 03:57 PM
BarrettsPrivateer
Apr 14, 2015 08:42 PM
Bag393
Jul 3, 2014 09:34 PM
1sweetglide08
Feb 15, 2011 09:47 PM
