need advise on SEPST Spark advance adjustment advice
Old Aug 8, 2020 | 06:31 PM
Keithgordon092's Avatar
Keithgordon092
5th Gear
Default need advise on SEPST Spark advance adjustment advice
so, here is my question. I have a 2019 Road Glide 107 I just put a stage 1 kit (screaming eagle heavy breather, Tab zombie 4" slip ons and the Harley screaming eagle pro street tuner)
Yes, I know there are better tuners, but I want to keep my warranty. I have done several data record sessions and am getting the VE front and Rear cylinders pretty close to where I want them. Bike runs good. I am noticing it is running hotter than before I did the Stage one kit and am confused about one thing. From what I understand you can adjust the front and rear spark timing, the front one will allow me to adjust it as much as 4 degrees. I cannot find in the tutorial that I have watched 20 times if I need to actually adjust it and if so will it screw anything up. I don't want to go in and just start screwing with the front and rear spark advance and cannot find any information on the internet to guide me. Can anyone try to explain to me if I need to adjust it and if so by how much or if by doing so will it screw anything up? And advice, tips, reassurance would be appreciated. Also if it is adjusted will it lower the temp at all? I cant seem to get a straight answer and when I call the stealership that sold it to me I cant get a straight answer.I am sure someone in here may have had this issue before and am hoping someone can help. I am just trying to get it dialed in properly without messing anything up.
Thanks in advance.
Old Aug 8, 2020 | 09:15 PM
Cogito's Avatar
Cogito
How do you know that your bike is running hotter now?
What temps are to seeing now? And what were the temps before?
Also, your bike has built in knock sensors and will adjust spark timing automatically.
Before trying to mess with spark timing you should first identify the root cause of the temp difference
Old Aug 9, 2020 | 03:09 AM
Keithgordon092
5th Gear
-4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 these are the ones that I can adjust on the front cylinder in the 80-100 MAP portion from the 750-1250 RPM range.
the rear cylinder will not allow any adjustment and are all white on the graph. the temp went from around 250 degrees up to about 300 degrees after the Stage 1 install. I know these engines do run hot due to EPA compliance, but I am trying to get as much out of this tuner as I can and was thinking that if I were to adjust these parameters it may help cool the engine and also decrease some of the ticking noise I have. I have a good grasp on the tuner itself just not on adjusting or decreasing the spark advance on the front cylinder or if I even need to. maybe I am reading too much into that portion of the tuner. I went to my local dealer to have it dyno tuned and they told me it was basically a waste of money to put it on the dyno unless I go to a stage 2 build, which I appreciate them saving me 3-400 dollars. I just am not sure if I even need to worry about fooling with changing the advance on the front cylinder. maybe i am worrying about it too much and should just let it be as it is.
Old Aug 9, 2020 | 05:14 AM
Keithhu's Avatar
Keithhu
I think you should take it to someone who knows what they're doing.
D Dot
Milwaukee Eight (M8)
Jan 27, 2020 08:58 AM
BigDipper15
Sep 7, 2018 02:36 AM
KJBennett
2014-2024 Touring Models
20
Oct 6, 2014 04:45 PM
matto371
Mar 24, 2013 08:06 AM
Dim100
Jan 23, 2010 11:09 PM
