screaming eagle street cannons
Old Oct 3, 2014 | 07:51 PM
KJBennett's Avatar
KJBennett
Default screaming eagle street cannons
I am thinking of instaling the screaming eagle street cannons and leaving everything else stock. My ?? is do i need to get the bike remaped or have anything else done. Dealer said I need to just not sure if it is necessary. I have the 2014 street glide special.
Old Oct 3, 2014 | 07:53 PM
2014sgs's Avatar
2014sgs
I put them on my 14 SGS didn't do a remap. They said it was fine not to...seems fine so far.
Old Oct 3, 2014 | 08:23 PM
Bricklayer's Avatar
Bricklayer
No need for a remap.
Old Oct 3, 2014 | 09:45 PM
MikeyTX's Avatar
MikeyTX
No, you don't need to. Should you ? Your decision. I did and it was worth the money. Keep in mind that the bikes run lean from the factory to keep the EPA happy. The rpm is capped too. The stage 1 download cures the lean tune and, allows the rpm to go much higher. I've also noticed that throttle response seems to be better, especially under roll on conditions. Plus, at some point you will most likely add a high flow a/c.
Old Oct 3, 2014 | 09:55 PM
p51bombay's Avatar
p51bombay
Fine without a tuner. FYI - these are nice and quiet, sound GREAT until you remove the cat equipped header pipe - if you do remove the cat you'll want new pipes.
Old Oct 3, 2014 | 11:23 PM
Joe S.'s Avatar
Joe S.
Can't say about having to. I put them on my bike and also put on the HD hi pro air cleaner then had it mapped with a SE super tuner. I can only tell you it runs really good and puts out about 84 hp, runs cooler and . In my way of thinking it was worth it.
Old Oct 4, 2014 | 08:36 AM
Kilokato's Avatar
Kilokato
Mmmm....I have read several folks have a lot of deceleration pop when they let off the gas with the Street Canons???...I was looking for a set until I decided too many people complained about the popping sound...
Old Oct 4, 2014 | 09:39 AM
MikeyTX's Avatar
MikeyTX
I had that too until I had the stage 1 download installed. It stopped. Throttle response got better too.
Old Oct 4, 2014 | 10:26 AM
hbsoldier3's Avatar
hbsoldier3
I just installed these on my 2014 Limited yesterday. They have just the right sound, mellow, some bark when on the throttle. Have a little De-cel pop once in awhile. Going to the dealer today to get Stage 1 kit installed and remapped.
Old Oct 4, 2014 | 10:41 AM
scottt's Avatar
scottt
+1, I have street cannons with the stage one flash and A/C. Works great. I am happy camper.
