USB error message
Old Apr 25, 2022 | 10:10 AM
raciohurg's Avatar
raciohurg
1st Gear
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->You can see the reason why you get this error on the screen. If you engine the car, you won't get this error. I had a similar situation with my car. I use a USB data holder for listening to music in the car. I was always getting errors that it was using too much energy, so I needed to unplug it. After beginning the car, the error disappeared. I have used some hard drive recovery services, and I found out that the USB data holder was corrupted, and after it was cleared from viruses, the error disappeared.
Old May 31, 2022 | 01:24 PM
Litesdb's Avatar
Litesdb
Stage I
I had the same error and got rid of it by removing the cloth USB cords I had running across the head unit. I think maybe because they're not insulated well causing interference with the unit. I also removed the carplay jumper plug I installed and now just use the stock USB port and bluetooth. No more problems.
Old Jul 30, 2023 | 03:25 PM
voodoodrug's Avatar
voodoodrug
2020 once had an after market usb cord,-->ezy fix
next problem recently, narrowed it down to the boom gts usb connector. radio went from disconnecting to error message to full blown crazy blinking.
CRC contact cleaner blasted it. bikes 4 years old. seems to have worked and makes a lot of sense to try that first, contacts get a lot of cycling from condensation?
Old Oct 12, 2023 | 02:39 AM
Alex0222's Avatar
Alex0222
Stage I
Default USB error message.
I searched on every forum on internet and eventually end up fixing this by making sure the device is completely dry.
bjdmsh
2018+ Softail Models
18
Oct 13, 2021 04:34 AM
Bafflingbs
Jun 10, 2020 07:06 PM
Madnss
Jan 18, 2016 01:06 PM
Bagged Sbob
Jul 26, 2015 04:14 PM
