External breather for AC/DC or Stealth aircleaner?
Looking for recommendations for an external breather for Fuel Moto AC/DC or S&S Stealth aircleaner. I'm running my oil level 4 holes down from full on the dipstick and still getting quite a bit of oil in the AC/DC airfilter. I know there are kits available to drill and tap the air filter backing plate to install nipples to run vent lines. But the AC/DC and S&S Stealth are both a composite backing plate with brass inserts where the breather bolts go. Not sure if a drill and tap kit would work with this sort of backing plate. Has anyone done an external breather on these airfilters?
What bike & Year? I had the issue on my 17 w 117 build and vented the oil sump (dipstick) and it cleaned it all up. Easier!!!
Im looking at doing the same exact external breather setup with my S&S Stealth intake. The issue I see with the S&S and AC/DC is how the breather holes are not directing the oil back into the intake like the HD intake does with the rubber hoses. The oil from the S&S just sort of drips down and not necessarily is directed back into the intake throat via a rubber hose barb. Either way, Im looking to make this an external breather set up.
I do think Ive seen people drill and tap the composite/brass intake just as they would with an aluminum one....
I did my stealth in the exact same manner as my other, drill/tapped for push connect fittings and plugging the ports that lead into the intake
photo is of my previous setup but the method is the same
I have the FM/S&S AC/DC / Stealth air cleaner on two bikes with big displacement builds. I thought about drilling, tapping, etc, but decided to use the Harley OEM breather bolts instead.
Install has yet to occur, but I have the bolts, just need to pick up some tubing and fittings, and decide on a catch can or breather filter.
