Stripped Spark Plug Hole
Old Jun 8, 2021 | 04:13 PM
702's Avatar
702
Default Stripped Spark Plug Hole
If you somehow strip the threads in a spark plug hole like I did, don't panic.
Find an M10x1 thread chaser, coat it with grease to limit any shavings dropping into the cylinder, and see if you can repair the threads. Be careful not to run it in too far, if it falls into the cylinder you might say bad words. Also, make sure to clean the threads afterward with a rag soaked in Brake Kleen or something to get the grease out as much as possible.
I got lucky, and was able to torque the new plug to 110 in lbs with no issues.
Old Jun 9, 2021 | 06:03 AM
borrec's Avatar
borrec
It did that taking it out? Was it the right rear plug? When I changed mine and was putting new ones in the right rear seemed like the threads were not as clean as the other 3. Went in and torqued but had more resistance.
Old Jun 9, 2021 | 07:05 AM
702's Avatar
702
This was the left front, and yes it came out that way.
Working it back and forth didn't help any, so I just pulled it. The top 3/16" or so of the threads in the head were shot.
Old Jun 9, 2021 | 07:27 AM
tyrant33's Avatar
tyrant33
How many miles do you have? And was this the first time you changed them out?
Old Jun 9, 2021 | 07:37 AM
702's Avatar
702
I last changed them at 17k, and I have 31k on it now.
Old Jun 9, 2021 | 08:29 AM
plongson's Avatar
plongson
Well that sucks ***...that's something ya never want to see. Glad you got it straightened out though.
I use Never Seize on plugs (and everything aluminum getting a bolt or screw) and cringe at the thought of Loctite blue and never use red in aluminum, but that's just me.
How's the tune running Larry??
Old Jun 9, 2021 | 10:42 AM
702's Avatar
702
It's running great.
Old Jun 9, 2021 | 12:34 PM
jake24lt's Avatar
jake24lt
It has been been known to happen if you remove plugs while the engine is still hot. Not saying you did, but just mentioning it.
Old Jun 9, 2021 | 08:31 PM
FDHOG's Avatar
FDHOG
Happened to me on my 2002 Fatboy. Had to put Helicoil in and it ran great for years after.
Old Jun 9, 2021 | 08:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Played this game many a time, my kit just for fixing spark plug holes. Got the thread chasers too for the salvageable ones still on the bike.
