DTC Error Codes
Old Jun 21, 2022 | 06:23 PM
bradsULtd's Avatar
bradsULtd
Originally Posted by Oilfieldoutlaw
I've got a 22 SG special that I bought with 1 mile on it and jus today, I had the same codes thrown. In addition to 2122&2127. Have u had any luck in finding the root of the issue. I'd be appreciative to know.
How can it have just one mile on it?? The 1 mile is from the factory test riding it...the process is the Dealer must test ride all bikes after they do their thing (minor assembly/ adjustments), for at least 4 or 5 miles or more before getting it into customers hands...
Old Jun 21, 2022 | 06:40 PM
FLTRI17's Avatar
FLTRI17
Feels a bit trollish IMO.
Old Jun 21, 2022 | 06:54 PM
bradsULtd's Avatar
bradsULtd
Yup!
Old Aug 17, 2022 | 07:22 AM
JasonU71's Avatar
JasonU71
6th Gear
Originally Posted by DC2009EGUC
Bike is a 2021 Road Glide Special mileage at 1200 and for some weird reason, bike is getting EMC and ABS DTC codes and it has happened twice at the same gas station Chevron gas station after taking on fuel. Bike typically will refuse to start and no matter if I shut and ignition switch to on or off. On checking DTC, these are the codes that bike shows:
First incident May 29, 2021 ECM - P1100h, P1511h, P1600h, P2100h, P2105h and ABS - C1100h (First incident shows "h" at each of the codes)
Second incident August 6, 2021 ECM - P1100c, P1511c, P1600c, P2100c, P2105c and ABS - C110c (Second incident shows "c" at each of the codes)
Dealer says unless they actually see it at the show, they can’t do much and to start the bike and get home, I need to clear the codes and all I can do is take a photo as proof. Anyone here experienced these intermittent codes? If you did what was the fix, I am thinking perhaps wiring issue or component that is being impacted when the bike heats to operating temperature, or could it be the fuel at the Chevron gas station or some sort if RF energy “zapping” the bike EMC…not sure but just trying to make some sense on the new ’21 M8.
By the way, bike is bone stock.
Interesting, my 2022 FLHP has popped the same codes twice directing following a fill up, albeit it was at two different gas stations. Both times the motorcycle refused to start for about five minutes. I'm wondering if DC2009EGUC was able to resolve this problem?
Old Aug 17, 2022 | 09:20 AM
Pappy35's Avatar
Pappy35
Did you look up the codes? If you did, I missed it.
Old Aug 17, 2022 | 09:48 AM
smitty901's Avatar
smitty901
Is the bike still in warraty? If so then next time it does it call the dealer and tell them to come get it.
Old Aug 18, 2022 | 03:25 PM
DC2009EGUC's Avatar
DC2009EGUC
Wow it’s been a year already this month since made this post and I am happy to report that..."knock-on-wood", the DTC has never came back and of course, the "useless" dealer is of no help until I can proved it is happening on the spot, but we all know these intermittent problems are very hard to replicate...
So what was the fixed...I removed the piece of $hit seat that I got from Amazon:
Amazon Amazon
I reinstalled the factory OEM seat and the problem never came back. What I think happened is due to the very low nature profile of this copycat CVO solo seat, it is not allowing enough room from the bottom of the seat to the ECM connectors and all my other Custom Dynamic run/brake/turn connectors and consequently, it would put enough pressure on the ECM circuit board connectors which results in these DTC error codes. Then you add the summer heat and humidity, I think in my case it creates this “perfect storm” environment…who knows…but the good news its never been back…
Please let us all know if you have changed your seat and are experiencing this same issue, if not, double check you ECM connector, make sure it is clean and dry…
By the way, I replaced my OEM seat with a Saddlemen Step Up SDC seat, and yes I made sure it has lots of room… hope this helps and I can close this case.
Old Aug 21, 2022 | 11:23 AM
Fullbore55's Avatar
Fullbore55
DC, thanks for the update!
Old Oct 19, 2022 | 12:18 AM
rachelgomez161999's Avatar
rachelgomez161999
2nd Gear
The easiest way of clearing codes is to fix the problem, and it’ll automatically get erased.
Before OBD-II was introduced, many vehicles let car owners disconnect the battery cable or the computer’s power source to clear the OBD codes.
Disconnecting the battery or power source means no voltage, which would clear the computer’s temporary memory, and the check engine light would turn off too.
However, the latest OBD system stores the DTC codes in a memory that doesn’t erase, even if the battery or computer’s power source is disconnected.
Every fault code stays in the memory until you or your mechanic clear them with a scan tool.
Greeting,
Rachel Gomez
rhallman
2014-2024 Touring Models
Mar 1, 2025 09:08 AM
tomcatg
Jul 2, 2018 07:29 PM
Fscott4
15
Apr 23, 2017 01:01 AM
Tedjay
Jul 9, 2016 04:59 PM
striper.seeker
Jun 30, 2016 07:41 PM
