M8 128 build horsepower and torque issue
Old Dec 17, 2021 | 08:43 PM
rsaltzmann's Avatar
rsaltzmann
3rd Gear
Exclamation M8 128 build horsepower and torque issue
Hey All, looking for some advice or feedback on my 2019 Road Glide Build. It is at the dealer and the technician is having trouble getting better numbers from the original build that was 130+ HP and 140+ tq. After having the heads completely done by Branch&Okeefe and adding the Fueling 592 cam the numbers stayed the same. The Tech is scratching his head as am I, we expected a much better result. Is it the Throttle body, ECM, cant figure it out? the tech wants to try a larger TB, thinking not enough with all the work dont to the heads and the larger cam........Any suggestions. We thought we would be high 150's-160's hp/tq The build is below.
S&S 128 Kit
Feuling 592 Cam
S&S QUICKEE PUSHROD KIT
Darkhorse Balanced crank w/balancer removal (Cirrilo rods)
B&O inc heads oversized valves
S&S Premium Tappets and Tappet Cuffs
S&S Roller Rocker kit
Darkhorse Compensator
Trask Clutch Basket
Rekluse Torq-Drive Clutch
HPI 62mm Throttle Body
HPI 6.2 injectors
Fueling Narrow Band O2 sensors
PI V2 air cleaner
S&S Oil Pump
Fueling Cam Sproket
AIM Clutch Slave
AIMSDR Clutch
D&D Billet Cat Exhaust Big Bore Baffle
Drag Specialties Performance Coil NGK Iridium Plugs (IX CR9EIX)
Screamin Eagle 10mm plug wires
Old Dec 17, 2021 | 09:06 PM
mjwebb's Avatar
mjwebb
here's where you want to be redirected to..where the professionals / subject matter experts reside
https://www.hdforums.com/forum/ignit...-injection-55/
and The Dyno Room section
Old Dec 18, 2021 | 07:56 AM
FLSTFI Dave's Avatar
FLSTFI Dave
What tuner are you using?
What is the compression set at? What is the deck height? These to can make a big difference.
Old Dec 22, 2021 | 07:01 AM
Mchad's Avatar
Mchad
If his dealer did the install, it’s unlikely anything other then bolt on was done. So if so, the S&S standard 128 kit is 11:1 comp. I don’t know that cam but those numbers are what I’d expect from a mediocre tune. A good dyno shop should get another 10 on each side.
And I thought I read somewhere that M8’s don’t like iridium plugs? Put stocks back in maybe.
Old Dec 22, 2021 | 12:15 PM
Oldskewl's Avatar
Oldskewl
The Zippers Big Bore 128 kit is 10.9:1 compression using a Red **** 552 Cam making about 155HP / 160TQ with only #225 lbs of cranking compression. Of course that requires TB, injectors ect ect
Old Dec 22, 2021 | 01:08 PM
$tonecold's Avatar
$tonecold
The problem I see here is that you changed two things. Either one or both could be the problem. One thing is, what heads did you send in to have reworked? For the most part, the stock heads flow about as much as you need. The ports on them are bigger than the ports on the SE heads. Just shows that a bigger hole doesn't necessarily mean more or better flow.
I would go back to the cam that you had in it when you first dynoed it, see what you get then. If you do better, then you know the heads are working, making more power. If you do worse, then I would say the heads didn't do anything for you. By the way, you didn't say what cam you were running when you dynoed the first time.
Old Dec 22, 2021 | 01:14 PM
Mchad's Avatar
Mchad
Too big slows down the charge velocity, is that it?
Old Dec 22, 2021 | 01:18 PM
OldMike's Avatar
OldMike
Is this your bike?
Old Dec 22, 2021 | 03:44 PM
$tonecold's Avatar
$tonecold
Yeah, that's part of it. There's a lot I don't understand about it, but this I know, just because it looks good on the flow bench doesn't mean it will work well on the engine.
Old Dec 22, 2021 | 03:57 PM
Oldskewl's Avatar
Oldskewl
Originally Posted by OldMike
Is this your bike?
After seeing 5 builds all produce the same results, I ordered it for my bike last week. It's supposed to arrive any day.
