SE Ventilator AC
So I put one on, but can’t speak from much experience. I also installed a DK Custom breather kit to vent the crank case fumes and crud to a filter I routed under the oil cooler shroud.
So I put one on, but cant speak from much experience.
I ran the older twin cam version for years on my 07, 09, 10, and 14 and those did suffer in an extremely heavy rain - mostly on the batwings, but it did happen occasionally on my Road glides now and then.
I guess my batwings directed air/water right to the air cleaner more than my RGs.
Anyway, for those who have never experienced it, you know it's soaked and sucking water when you're incrementally (and unconsciously) giving it more and more throttle to maintain speed.
Then suddenly the bike will miss hard (no combustion) - for like a long 2-3 seconds until the engine suddenly lights off again but now you're doing 40 instead of 60.
Never a problem scooting around town, but I've run into it mostly on long runs in the middle of nowhere and I'd happen to run into a storm on a road with no over passes or convenient places to stop etc - just pushed through.
I learned to put the rain sock on when in those situations and everything would be fine.
So that brings me to my 17 and it's newer ventilator. I've been in a few downpours and never had this problem and I don't even own a rain sock for it. Go figure.
