Updated oil pump?
Old Sep 27, 2022 | 02:40 PM
euchre98's Avatar
euchre98
Default Updated oil pump?
What is needed to update a '19 to the latest oil pump? Just the Pump and o-ring?
Old Sep 27, 2022 | 03:48 PM
rmc115's Avatar
rmc115
Nope, need the whole pump kit, geroter gears changed from 10 lobe to 8 lobe. Doing a 18 limited right now. There is a tsb on pump identification if apart. Mike
Old Sep 27, 2022 | 04:42 PM
Keithhu's Avatar
Keithhu
https://static.nhtsa.gov/odi/tsbs/20...64800-9999.pdf
Old Sep 27, 2022 | 07:15 PM
bradsULtd's Avatar
bradsULtd
Depends on what kind of motor you have:
Oil-cooled Kit P/n: 62400247
Water-cooled Kit P/n: 62400248
Old Oct 4, 2022 | 12:28 PM
mikes300's Avatar
mikes300
its possible your 19 already has the updated pump too.
Old Oct 4, 2022 | 02:23 PM
bradsULtd's Avatar
bradsULtd
If the bike manufacture date is before May 22, 2019 then highly unlikely he has new pump unless previous owner (if there is one) installed it...
Old Oct 10, 2022 | 08:56 AM
FunHuman's Avatar
FunHuman
FYI my 2021 (SE HD 131 kit) is sumping. 65-80mph no problem 90+mph starts to sump. If you can I would recommend doing the HD SE pump. Mine going in for the swap next week.
Old Oct 10, 2022 | 09:02 AM
bradsULtd's Avatar
bradsULtd
What oil pump are you using right now, that's sumping?
BTW inserts I got from you are working pretty good!
Old Oct 10, 2022 | 09:06 AM
DaveyFB's Avatar
DaveyFB
I have a 2019 but the Mfg date is Sept 2018
I have no problems at present w/sumping
But if (when) the engine gets opened fort Stage 2/Cam it will be replaced
Old Oct 10, 2022 | 10:14 AM
dajogejr's Avatar
dajogejr
My 19 limited is April of 2019. 25K miles plus and no sump issues. It’s truly bike by bike.
I’ve spent too much time, honestly, on the super slab doing 80MPH plus blasts.
I know some riders haven’t been so lucky.
I too am in the camp of, when it gets opened up for a cam, it’ll be upgraded just because.
