I've never understood the comments on this Forum that conclude V Twins can run up to 6k rpm we should run them high rpm.
if that's the case, why not just buy a Japanese 6 cylinder bike with a half inch stroke and run at 10,000 rpm all day? I don't get it. At all. Harley's are stroker motors for high torque at low rpm. Because a different mode of operation is possible, why would you restrict operating there?
I rode the 4 cylinder Hondas. They start picking up torque around 5,000 rpm, like a 2 stroke snowmobile. Exactly what I do not want in a motorcycle.
Stroker motors don't make any more torque than a short stroke motor of the same displacement. In fact a shorter stroke motor can make more tq if the rod to stroke ratio is higher. As long as you are reasonable with the pistons speed, why not use it??
Disagree. Strokers have a longer moment arm crankpin yielding higher torque for given displacement. There would be various bores and strokes for given displacements otherwise.
Do the math.. The longer stroke means less square inches on the top of the piston if the displacement is the same.. Less square inches means less force on the rod which ends up to be the same torque.. Rod to stroke ratio in important here.. If the same they generate the same amount of torque.
I don't spend much time there, I'm typically still shifting around 5500-5800 RPM when I'm really ripping on it, but you CAN run it up that high if you so choose. For most of my day to day fun I'm ripping between 3k-5400.
Now, why am I doing that instead of getting a cam that emphasizes low end torque? Because I want to, and I can. If I blow the motor, oh well, I'll build another or pay someone to do it for me.
I don't have the time/space for another Ducati right now, so this is helping fill that hole in my heart until I can get another one.
Incorrect. Wanna do some calculus? For the same displacement, I said. Same volume, same pressure provides more torque with a longer moment arm.
No calculus involved. Simple vector analysis.. First semester physics. Need to know your trig and the fact that force = pressure times area.
Now for the same bore, if you increase stroke, you increase displacement and therefore increase torque.
Add:
Actually there will be calculus involved if you want to integrate over the stroke.. In that case I cheat and use a spreadsheet.. Analysis at a rod angle of 90 degrees is good enough tho.
While yalls are exploring the merits of rod length...
I'm just over here debating between the 22XE and the 777XE.
Potentially 125hp at 6000 RPM. Redline of 6200...
Versys 22XE at 120hp from 5500 to 6000, redline it at 6200 and it'll carry that 120 all the way. But the 22XE has so much low end torque as well.
777XE would require me to get 5.5injectors though, and it's a more expensive cam, would be 500$ for me.
Where as a 22XE is 352$
I hear though it's bad for longevity going over 5500~6K RPM.
BTW longer stroke does not make low end. It makes torque everywhere.. VE is where the difference comes in..
I was one that thought longer stroke made more torque, shorter stroke made more HP, hence the longer stroke allows more "burn per stroke" (piston has to travel further, allowing gas to expand more) and why long stroke, low RPM engines are used in diesels. ??
They will make similar tq / hp (it's improbable they would be exact, as even mirror image builds can be different). What changes is the rpm where each one peaks. Diesels are a different animal, they do generally have longer strokes but there are over square engines around
