Throttle position sensor
Old Apr 24, 2023 | 06:05 PM
robbie52's Avatar
robbie52
Default Throttle position sensor
Has anyone had or heard of recent problems with the throttle by wire system? I lost throttle control and went into limp mode yesterday. Ended up stranded about 150 miles from home and had to tow bike. Bike going to dealer tomorrow, but wondering if anybody has had this issue lately. I had this issue on my 2009 limited but not aware of recent issues. Bike is a 2022 Road Glide CVO Limited.
Old Apr 24, 2023 | 06:25 PM
702's Avatar
702
I haven't seen any reported problems here. Have you tried performing a throttle reset?
Old Apr 24, 2023 | 07:29 PM
rideonva's Avatar
rideonva
Did you pull any diagnostic codes ? I assume there should be if bike went into limp mode, that should give a clue on the cause.
Old Apr 25, 2023 | 11:26 AM
robbie52's Avatar
robbie52
Just found out it is the throttle body and part on back order until 7/23. Trying to locate one at another dealer now.
Old Apr 25, 2023 | 12:05 PM
TriGeezer's Avatar
TriGeezer
Anything can happen to anything. One pre 2014 models there was no cover on the big connector and the terminal,pins would corrode. Maybe open the connector and check out the condition of the pins..
Old Apr 25, 2023 | 12:19 PM
Jackie Paper's Avatar
Jackie Paper
Glad it's under warranty.. throttle motor is it's a $350 part that is a permanent part of throttle body. Interesting back when they went that way, the throttle body was a lot cheaper then in previous years and still is.
Ronnie's shows it available but that doesn't really mean it is till you talk to them.
Your bike is so new, the fish hasn't even been out long.
Old Apr 25, 2023 | 03:15 PM
robbie52's Avatar
robbie52
I assume that means the throttle body position sensor is part of this too. What is the part number?
Old Apr 25, 2023 | 06:32 PM
Jackie Paper
The throttle motor is your idle control and position sensor. It replaces the IAC and TPS. You do have a separate temperature sensor and injectors in intake. I could be wrong up in the other post. It appears the motor may be separate. The body is $346. I now think the motor is $262. Look at the fish.
27300122
THROTTLE BODY ASSEMBLY, W/ REF # 4 262.49
27200025
MANIFOLD THROTTLE BODY INTAKE KIT, W/ REF # 11, 13, 5 345.99
https://partsfinder.onlinemicrofiche...avidsonmc/2022
Old Apr 27, 2023 | 07:55 AM
robbie52's Avatar
robbie52
27300122
27200025
They are replacing the throttle body assembly, part # 27300122. Dealer was able to locate one at another dealer. Looks like this part is same on all M8 touring bikes and hard to believe they are backordered for 3 months.
Old Apr 27, 2023 | 07:48 PM
Redrodyankneck's Avatar
Redrodyankneck
[QUOTE=robbie52;21183881]They are replacing the throttle body assembly, part # 27300122. Dealer was able to locate one at another dealer. Looks like this part is same on all M8 touring bikes and hard to believe they are backordered for 3 months.[/QUOTE
If they are backordered that long maybe it's in high demand, let's hope that isn't the case.
