Weird start up after cam
Old Dec 26, 2023 | 09:40 AM
b1gb2010's Avatar
b1gb2010
Default Weird start up after cam
Installed a wood X22E , FM adjustable pushrods, and S&S lifters, SS tappet covers on my 2022 road glide
I have a Bassani 2/1 and SS tear drop air cleaner
flashed the tune from fuel Moto. I think the bike is running OK once it’s warmed up but every time I start it from a cold start, the idle goes up and down erratically for the first 30 to 60 seconds then it seems to stabilize
Any ideas what can cause this or is it more than likely in the tune? Could an exhaust leak at the head pipe gaskets cause this?
once it’s warmed up and I take it out, I don’t think I noticed any hesitation or anything like that
I think I might hear popping once I let off the throttle but I’m not sure if it’s just the sound of the cam while riding since I’ve never installed this on a bike before.
Old Dec 26, 2023 | 10:33 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Most commonly if you installed the cam & flashed the new tune the learned idle and closed loop parameters have been reset and it will take several run cycles for the ECM to relearn as these are adaptive. If you need any additional assistance you are welcome to reach out to us.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Dec 26, 2023 | 10:51 AM
NCPiper's Avatar
NCPiper
Help me learn.
The adaptive process mentioned would happen even if the O2 sensors have been removed?
I am going with the assumption (yep, I did that) that the O2 sensors have been removed with the Bassani 2-1.
Thank you for your patience and teaching moment.
Old Dec 26, 2023 | 11:58 AM
rigidthumper's Avatar
rigidthumper
The O2 sensors should have been transferred from your stock exhaust to the new 2-1.
Old Dec 26, 2023 | 12:46 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by NCPiper
Help me learn.
To clarify, if you are changing exhaust systems the O2 sensors should be installed in the new exhaust. O2 sensors are used for closed loop fuel correction, including our tunes.
Old Dec 26, 2023 | 12:50 PM
b1gb2010's Avatar
b1gb2010
definitely transferred the O2 sensors lol
Old Dec 29, 2023 | 07:04 AM
2017M8's Avatar
2017M8
Well you said you installed the SS air cleaner, some of the original brackets have to be removed and not put back on with the New Air cleaner, double check the directions on RR the AC, if you leave original brackets in place that may / will cause leaks etc.
Old Dec 29, 2023 | 04:28 PM
OzRGS's Avatar
OzRGS
I got a tune from V&H (amazing tune - heaps of power). The revs drop for a half a second about 10 seconds in, sounds like its going to stall, but kicks back up to high idle. This happens every time for the past two years, about 50 cold starts. Doesn't happen when i'm out and restarting, only when starting before riding.
I'm not stressed about it, happy with the tune.
Old Dec 29, 2023 | 05:09 PM
pgreer's Avatar
pgreer
You really should start your own thread for the specific issues you are having, including the upgrades and tuner you are using to keep any response from being confusing about what they are replying to. And you are more likely to get responses to your questions that may be helpful.
And you could ask a Moderator to move your post for you.
Paul
Tire_Fryer
Twin Cam Motors
15
May 2, 2022 11:51 AM
gdishman
Twin Cam Motors
Jan 2, 2021 12:04 PM
Eyolv Holm
Engine Mechanical Topics
May 31, 2019 02:28 PM
Krazy8s
Apr 2, 2019 02:32 PM
Dsrt
Dec 12, 2014 05:48 PM
