Need Help
Old May 1, 2024 | 04:28 PM
evildiesel's Avatar
evildiesel
subscribed, I'm interested to see what you find. also, be sure it's not your compensator ramp that broke, seem to see a few of those lately. are you sure it was on the right side of the bike?
Old May 1, 2024 | 05:43 PM
Bandit777's Avatar
Bandit777
not certain going to definantly check as I heard this mentioned too
Old May 1, 2024 | 11:29 PM
Bandit777's Avatar
Bandit777
Not the compensator so I suppose it’s narrowed to lifter or rods. Not sure what else to check. I wanted to throw a new set of lifters back in and see what happens figure if it’s rods I’m screwed anyway, but had more bad luck and 1 of the tappet cuff bolts sheared on me so working on that now. Bad start with this bike but it has a back story for me so I’ll get it fixed whatever it takes.
Old May 7, 2024 | 10:53 PM
Bandit777's Avatar
Bandit777
Attached is a video of the noise. Just installed fresh lifters obviously it was them. I ran let it warm up for a bit and no luck. Maybe rocker arms but I’m not sure debating if I want to take a stab at it or bring to a shop to diagnose.
Old May 7, 2024 | 11:00 PM
evildiesel's Avatar
evildiesel
I can’t see an attached video
Old May 7, 2024 | 11:19 PM
Bandit777's Avatar
Bandit777
Here it is.
File Type: mp4
Old May 7, 2024 | 11:22 PM
evildiesel's Avatar
evildiesel
Take a wooden broom stick or a wooden dowel or handle of some sort, put it right to your ear and start touching parts of the engine with the other end. Use it as a stethoscope, works very well and it’ll point u in a direction where it could be coming from. Put it on the valve covers to see if it’s coming from there and which one
Old May 24, 2024 | 11:25 PM
Bandit777's Avatar
Bandit777
Default Update
Here’s the damages. Rear piston scored ang gouged cylinder wall. Looks like front piston started to have minor scoring as well on cylinder wall. I don’t know what I’m doing is there other things I should look at before installing a new kit?
Old May 25, 2024 | 07:27 AM
Tharber's Avatar
Tharber
Thats problematic however thats not going to be your knock. Thats piston skirt scoring and maybe a little ring damage from assembly.
Pull the heads, take a hone to them and order a new set of rings and make sure you get the placement of the rings correct. I realize your existing rings could have spun around but they do not appear to be placed correctly.
Scotch brite the pistons and make sure they are 100% clean with a no lint towel and use plenty of oil before punching the pistons in.
Old May 25, 2024 | 09:00 AM
Bandit777's Avatar
Bandit777
I will add this is the second time this engine has killed pistons. Last was a screaming eagle stage 3 kit now this fuel moto 124 wondering if possibly piston oilers are not functioning properly I will pull them next.
regarding the knock/tapping I’m not sure what exactly to classify it as. Is it possible this could be it. When I listened to the motor with screwdriver it sounded like the noise was coming from rear cylinder only than this is what I found.
