More compression
Old Sep 10, 2025 | 11:03 AM
Taxgod4u's Avatar
Taxgod4u
If I ever need more stump pulling power will outsource my math and assembly to Fuel Moto!
I am sure they will do a better job, even on a Monday, than I could ever do. They math gooder
Old Sep 10, 2025 | 02:32 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
If they are doing the build in house then they can measure your engine parts. If they are NOT doing your engine in house then they cannot tell you anymore than anyone else can. The problem comes from the way HD allows the parts to be made. That variation in the parts ie: crankshaft, rods, crankshaft centerline, case height, Cylinder length ect. is what causes the +/- 0.5:1 tolerance in the compression ratio and Fuel Moto cannot change that, nor can anyone else. So only way to know is to sit down and measure the parts, one at a time and make any necessary adjustments to get the compression ratio you are looking for.
Old Sep 11, 2025 | 03:27 AM
Slingshot383's Avatar
Slingshot383
To make sure it is correct, and same for both cylinders requires mock assembly to measure crank centerline to top of cylinder and then head volume and machine as necessary to get both cylinders equal to each other.
Schulte94
Exhaust System Topics
Nov 2, 2013 06:29 PM
N-gin
Sep 23, 2010 08:17 AM
customsoftail200
29
Feb 2, 2010 02:24 PM
Bad Disposition
23
Mar 6, 2009 01:38 PM
George C
Feb 3, 2006 11:08 AM
