Lifter replacement @ 60000
Old Nov 23, 2025 | 09:57 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by Funnel
Is the noise you were getting, gone now with replacement lifter?
Yes but I also set the lifter plunger to 0.125" depth instead of the usual 0.100.
Old Nov 23, 2025 | 10:00 AM
Funnel's Avatar
Funnel
Default Plunger depths
How did you do that and what does it prevent with new lifters, if anything.
Old Nov 23, 2025 | 10:07 AM
Max Headflow
Originally Posted by mjwebb
and what are the benefit claims / expectations going with the "new Hylifts that have the pin oiler" compared to the previous versions, longer service life, quieter....?
The pin oiler increases oil to the roller axle. It's supposed to increase roller bearing life. IIRC, @wfolarry said that Hylift had told him it helps ensure that the pin gets lubed on stationary motors that run at constant speed. Motors like big generators have this as a common failure. At certain RPMs the certain rollers may not get adequate splash.
Old Nov 23, 2025 | 12:24 PM
wfolarry's Avatar
wfolarry
I did say that
Old Nov 23, 2025 | 06:34 PM
Sullyxlh's Avatar
Sullyxlh
Whats the calculation to achieve that?
And are you running the SE or SEL lifters?
Thanks
Old Nov 23, 2025 | 07:40 PM
Max Headflow
Thanks
Push rods are 24TPI
SEL
Old Jan 17, 2026 | 03:25 PM
My79596!'s Avatar
My79596!
Stage III
Push rods are 24TPI
SEL
what's the part number for M8 hylifts ?
Old Jan 17, 2026 | 04:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The answer is here (Twin Cam and M8 lifters are the same) :
Home | Larry's Motorcycle Machine Inc
Old Jan 17, 2026 | 06:15 PM
Since 1968's Avatar
Since 1968
My 131 factory crate makes enough valve clatter noise that I'm not sure if I'll ever notice them getting worse....
topcat1st
Dec 15, 2024 05:33 PM
dontdropit
Mar 30, 2024 03:01 PM
FLSTFI Dave
Screamin Eagle CVO Models
Sep 12, 2022 09:00 AM
OldMike
May 20, 2021 11:15 AM
jrb1449
EVO
17
Jan 18, 2014 08:10 AM
