TDC Question
Old Mar 18, 2026 | 02:01 PM
waltjoldguy's Avatar
waltjoldguy
Stage I
Default TDC Question
I've just noticed the same thing you're talking about. It's been my assumption, and I think correctly, that the timing marks lined up at TDCC. Maybe not so anymore. Although stated in Feuling instructions to line up the marks at rear TDCC, if the marks are lined up properly, the piston is PAST TDCC. A recent H-D service manual does not say anything about TDCC. It says cam keyway at the top, crank flat at the top, install the gears. My best guess is the marks are for timing the cams, and that's it. They do not have a relation to TDCC anymore. And I've never seen this until M8's, and I think I would have noticed this before.
Old Mar 18, 2026 | 02:17 PM
roussfam's Avatar
roussfam
^^^^^ I ignored the marks, they were either just past or just before. I used the straw in the spark plug hole. Job is done, bike sounds great.
Old Mar 18, 2026 | 03:11 PM
Max Headflow's Avatar
Max Headflow
Evos, shovels, knuckles and pans were not at TDC when the marks lined up..
The flat lines up with the crank pin.
smvmarine
Engine Mechanical Topics
Apr 8, 2024 01:48 PM
OakMountainRider
Apr 17, 2022 03:35 PM
Am4wag
Nov 6, 2014 11:07 AM
justmealwatts
Apr 3, 2009 12:03 PM
smallmouth6810
Panhead
May 7, 2008 03:09 PM
