how bad are these wires?
Old Apr 13, 2015 | 06:57 PM
matt76cmich's Avatar
matt76cmich
Default how bad are these wires?
I was putting the brake back on and when it clamped right it pinched the right side control wires. How bad are these? I started the bike before putting everything back together, and now it won't start.
Old Apr 13, 2015 | 07:02 PM
J929626's Avatar
J929626
Bad enough to keep it from starting! They can be repaired though. Just cut and splice.
Old Apr 13, 2015 | 07:10 PM
matt76cmich
That's what I thought I was going to here. Looks like I'm going to go buy some wire, solder, and a soldering iron to learn how to solder wires together.
I was sooo close to going for a test ride of the new apes! Lol. As frustrating as this is, I'm impressed with completing the install with relative ease. Thank you to everyone that has posted tips and pictures of how to do this. It was extremely helpful.
Old Apr 13, 2015 | 08:23 PM
Sunnyday91360's Avatar
Sunnyday91360
Are the wires severed? Looks like they are just crushed a bit. You most likely blew the 5 amp fuse (not the main fuse) the batt fuse under the side cover. Replace the fuse and then you might be able just to un-smush the wires and tape where necessary.
Old Apr 13, 2015 | 08:53 PM
matt76cmich
They're not cut, but don't look the greatest. I just went out and checked the fuses, but I'm not that lucky. Every now and then (about 5 times) the fuel pump would kick on, but wouldn't turn over. Or fuel pump would turn on, turn over, but no spark. It actually started twice, but not consecutively. I'm hoping that I might be able to solder the wires where they are at after a little practice, otherwise I'll have to pull it to solder it, I really hope not lol.
Old Apr 13, 2015 | 08:59 PM
ChefRex's Avatar
ChefRex
Pull on the wire at the damage, if the copper is broken the insulation will stretch and break.
Old Apr 13, 2015 | 09:22 PM
gobblerhuntr's Avatar
gobblerhuntr
Fix em, trust me.
Old Apr 13, 2015 | 11:33 PM
Sunnyday91360
Ahh man, I was hoping for the best. Soldering it is... there are a couple of good videos on soldering wire on youtube, if needed. Oh, along with the soldering stuff, don't forget to get some heat shrink too.
Old Apr 14, 2015 | 03:35 PM
matt76cmich
Default Sweet Jesus
I got it done. Big thank you to ChefRex for the tip of pulling on the wires to see if there was a weak spot, and there was. The white and red striped wire was broke, only one. Got it soldered up, hooked the battery back up, and it fired up right away. Time to go enjoy this 68* Michigan sun.
Old Apr 14, 2015 | 04:56 PM
My14Ultra's Avatar
My14Ultra
Glad you were able to get it resolved so fast. Enjoy the new Handle bars!
