Oil Archive (no new posts) An archive of oil related questions and comments.
CASTRO 20w50 sYN
Old Apr 13, 2007 | 05:53 PM
Bushy's Avatar
Bushy
Default CASTRO 20w50 sYN
quick question. please don;t beat me up, anyone know in a nut shell whats the difference from castro 20W50 Syn and Amsoil 20W50 Syn?? Walmart has Castro doe $5.00 vs $10 for Amsoil.. anyone know for sure>> BEFOREI make a mistake and buy a few Qts>
Old Apr 13, 2007 | 06:31 PM
fatboylust's Avatar
fatboylust
Default RE: CASTRO 20w50 sYN
The Castro 20W50 you refer to is it the labled "Castrol V-Twin"? if so it specification meets HD's API SG and should be an excellent oil as is AMSOIL.
http://www.motodepot.com/product_det...1&sku=3335
http://www.smartsynthetics.com/amsoi...cycle_oils.htm
FBL
Old Apr 13, 2007 | 07:42 PM
iclick's Avatar
iclick
ORIGINAL: Bushy
What Fatboylust said so eloquently.
Castrol is an excellent brand, and I used their fossil GTX for years since the '60's. Even today I use it in my primary, and it's a great break-in oil. Any name-brand synthetic (Castrol, Mobil1, Royal Purple, Amsoil, Redline, just to name a few) will serve you well. Buy based on availability and price, and don't worry about it. One might carry you a few miles past 150k, another a few less. Forget the hype and go for it.
Old Apr 13, 2007 | 09:27 PM
bear95252's Avatar
bear95252
I am not condoning or condeming Castrol as they have been around a long time. Just for your info. The AMSOIL Study of Motorcycle oils Rated Castrol V Twin 16 out of 16 (one being the best) It failed miserable in tests like rust protection , gear wear test and the like. You can read the paper at www.amsoil.com and make your own decision. There are 15 oils better than castrol. I guess, in the long run, you get what you pay for. It is more readily available for sure. Motul is the most expensive MC oil you can buy but it is rated 9 out of 16. Go figure.
Old Apr 13, 2007 | 10:03 PM
liv2hunt's Avatar
liv2hunt
I don't care what the Amsoil chart says.. Castrol is great oil.. If the Castrol oil you want to buy says its for a V Twin use it..
Old Apr 14, 2007 | 12:20 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Look on the bottle before you buy it.......it should say API SG, SH/CF JASO MA on the label. If not then it's not air cooled motorcycle rated and you should not run it in extreme heat or past 2500 miles.
FWIW, I don't use Amsoil but it is excellent and will out perform Castrol. [8D]
Old Apr 21, 2007 | 12:38 AM
iclick's Avatar
iclick
ORIGINAL: bear95252
The Amsoil test was conceived, commissioned, and paid for by Amsoil. I've seen independent tests (e.g., Motorcycle Consumer News and American Iron magazines) that show Amsoil scoring well, but not as well as they claim in the tests posted on their website. There is no perfect oil, or a perfect oil for every aspect of a given application. All name brand 15w50 or 20w50 synthetic oils should perform very well in a Harley, and it doesn't need to be motorcycle-specific.
Mike650
Jan 31, 2013 08:48 PM
Topspin
Apr 14, 2012 10:52 PM
Modee1245
Sep 18, 2007 06:38 PM
monkish
11
Nov 13, 2006 08:20 PM
chilango13
Aug 16, 2006 01:24 AM
