Oil Archive (no new posts) An archive of oil related questions and comments.
Truth or Being BS'd???
Old Mar 24, 2018 | 08:53 AM
Phil_R's Avatar
Phil_R
Default Truth or Being BS'd???
Had a case at least of Amsoil 20w50 for motorcycle use, a couple of quarts of Amsoil 75W140 gear oil. This is all new in the sealed quart containers. Was going to use it in my new to me 2012 FLHTK. Since it is new, but old in the containers, probably have had it for 7 to 8 years, I called Amsoil headquarters and asked them if there was a shelf life of these products. I was told not to use it after 5 years of shelf life. I asked why it would go bad being in my heated / air conditioned shop? He said that the additives break down after that amount of time.
I went and bought fresh Mobil 1 V-Twin yesterday at Wal-Mart. (I get a discount as my wife works there). So, I guess I will dump (recycle) a bunch of Amsoil that cost a lot.
I was talking to a HD parts guy later and he said that was BS and the oil should still be fine. Would you use it and do you think it is true that it only has a 5 year shelf life of have I been BS'd.....?
Old Mar 24, 2018 | 12:24 PM
TN Houndog's Avatar
TN Houndog
Get out your hip boots you have been lied to! Oil in SEALED containers won't go bad whether it's 5 years or 50 years. It's dirt and contaminents that make it unuseable (the base stock NEVER wears out)
Old Mar 25, 2018 | 04:06 PM
xcbullet's Avatar
xcbullet
Shake then use it, the zinc settle on bottom. Or I'll pay shipping to me.
Old Mar 25, 2018 | 04:20 PM
2500hdon37s's Avatar
2500hdon37s
Fine to use.
Old Mar 25, 2018 | 05:58 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Amsoil? Lie? Say it ain't so!
Old Mar 25, 2018 | 06:27 PM
Jackie Paper's Avatar
Jackie Paper
You don't trust what the maker says and yet you think you are going to get a expert who has oil that old, used it and then actually knew how much or little damage was caused by using it?.. Seriously??
Not sure why you want to use the 75W-140 anyway. Even Harley says that is wrong for at least a couple measurable reason plus the age.
Old Mar 25, 2018 | 06:51 PM
son of the hounds's Avatar
son of the hounds
I,d worry more about old tires than oil sealed in its container.
As a motorcyclist for 54 years, I have not only used old oil, and mixed brands. If the oils meet the same specs, and I am a quart short, I'll use another brand.
I'd even worry about old belts, drive or even fan belts, as tires, belts, rubber items are not sealed and rot, oxidize, crack, age, fart or whatever.
Older engines were more forgiving. Modern engine depend on good additives.
Sealed oil, even if the additives were not as fresh as when new, will still protect. I'd check my oil condition and shorten the change interval. The key is unopened oil stored in cool dry locations. If it's been out in a shed, it has been through temperature and humidity changes.
When I've used older oil, bought in bulk, so 7-8 years old, there was no sediment. I used it.
My evo went 116,000 on Castrol, I bought two cases when I bought the bike. Still running strong when sold, though the fork oil was toast.
Last edited by son of the hounds; Mar 25, 2018 at 07:30 PM. Reason: The newer the bike, the higher the tolerance, the more the need for good additives
Old Mar 25, 2018 | 06:54 PM
Mikerunsjax's Avatar
Mikerunsjax
It may still be good. But, for the cost of oil, I wouldn't want to worry about it being in my bike. I'd buy new.
Old Mar 26, 2018 | 07:34 PM
kaynine840's Avatar
kaynine840
if it bothers you order another case of amsoil and send it back with the old ones in it saying you didnt need it
Old Mar 27, 2018 | 06:08 AM
Phil_R's Avatar
Phil_R
Nah, I would not do that as I feel that would be dishonest and not fair. I know a lot of folks would, but I still try to follow the golden rule.
