Oil Archive (no new posts) An archive of oil related questions and comments.
oil light
Old Jun 25, 2018 | 03:37 AM
weasel76's Avatar
weasel76
Default oil light
hi all ive just noticed my oil pressure wire broken on the sensor and when i start the bike the light still goes out any help
Old Jun 26, 2018 | 09:29 AM
bustert's Avatar
bustert
jpeg and model??
wish the forum had this info in the header like the xlforum does, big aid in knowing what is being worked on.
Old Jun 27, 2018 | 05:19 AM
weasel76's Avatar
weasel76
its a 2016 wide glide
Old Jun 27, 2018 | 09:40 AM
KarmaSportster's Avatar
KarmaSportster
Mine broke on my 17 WG and luckily it was still under warrenty because the wire was broken off right where it goes into the sensor. So the only way to fix it was to replace the sensor...and the whole wire harness. Although mine was covered, the harness itself is $600.
If you can't splice the wires together, you'll need to replace the sensor and harness. I can see if I can pull up the stock numbers when I get home.
Sorry bud.
Old Jun 29, 2018 | 06:45 PM
bustert's Avatar
bustert
http://partsfinder.onlinemicrofiche....0AND%20SENSORS
seems simple enough for repair. the sw is a NC unit that conducts to engine ground, when you start, oil pressure opens it up. if it still functions with wire off, def a problem in wiring.
or perhaps there is another sensor with the ecu, would have to get schematic. in the auto world, that switch acts as an egcy fuel pump circuit in case the relay fails, hd, i do not know.
Thumper09
Aug 2, 2019 07:44 AM
fooschamp
Feb 27, 2018 08:33 PM
DanMan1
Shovelhead
Jun 23, 2013 02:24 PM
discodave
Aug 21, 2011 07:51 PM
Booey424
Apr 29, 2008 02:12 AM
