Oil Archive (no new posts) An archive of oil related questions and comments.
Redline Shockproof - Leak
Old Jun 29, 2007 | 11:25 AM
norfolk88's Avatar
norfolk88
Default Redline Shockproof - Leak
I just read on another post in the "Primary/Transmission/Driveline" forum that some individuals have had an issue with a leak developing between the primary case and the tranny case. A lot of individuals posted "me to" posts who were using Redline. They thought there was some connection between Redline and that seal. I've had Redline Heavy in my tranny for about 4,000 miles with no issues... has anyone using Redline experienced this? Or are these guys fishing for a connection?
Old Jun 29, 2007 | 03:02 PM
WildBill2566's Avatar
WildBill2566
Default RE: Redline Shockproof - Leak
Never had a problem, or heard of one to be honest. I cant see the oil being the cause for a leak.
Old Jun 29, 2007 | 03:42 PM
EZ2Rider's Avatar
EZ2Rider
This comes up from time to time and here is what the expert consensus seems to be. The sealwas a weak spot on our engines. The fact the redline is red, makes the leak more obvious and identifies its presence and where it is coming from. with other lubes, it often goes farther before diagnosis or even notice. The redline is NOT the cause of the leak.
EZ
Old Jun 29, 2007 | 05:19 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
No leaks.................yet But I can see why the shockproof heavy would leak being that it's so thin. It's what 75w250? That **** takes a half hour to pour out of the bottle.....
Old Jun 30, 2007 | 10:22 AM
1flhtk4me's Avatar
1flhtk4me
I was was one of the "mee too's" but I'm not linking the two together.
I have had the Heavy Shockproof in for a little over 5K miles.Its a fact of life that some seals will develop leaks with dino oils or syn. IT's the seal or shaft that is the cause.
Old Jun 30, 2007 | 11:07 AM
danzio's Avatar
danzio
That may be my post your referring to and I in no way tried to link the Shockproof as the cause of the leak. I have been running it for about 3k miles and I really like the feel it has given to the shifts, my gearbox is quiet, no problems finding neutral and all that stuff. As a matter of fact, if it's gonna' leak, having that pink goo visible at the area of the leak makes diagnosis that much easier. Now having said that, I am still trying to find out what seal is the culprit. It is not the main shifter shaft seal, it is further back and when viewing from underneath, it appears to be coming out of one of the eight screws that holds the cover case on. The screw closest to the primary case above the primary oil drain plug. Gonna' go run it again today and try and get a better look for other possible areas of the leak.
Old Jun 30, 2007 | 12:39 PM
R_Einan's Avatar
R_Einan
ORIGINAL: KBFXDLI
[sm=funnypostabove.gif] Damn dude, you should do stand up; 'cause that was some funny chit man!
RE
bigdog1949
Sep 3, 2019 08:57 PM
djw
Apr 20, 2009 01:52 PM
Timboto
Shovelhead
Mar 1, 2008 07:05 PM
52edub
Nov 3, 2007 01:26 PM
Quickie
Sep 9, 2007 09:59 AM
