Oil Archive (no new posts) An archive of oil related questions and comments.
inch pounds to foot pounds?
Old Jul 14, 2007 | 05:26 PM
burnafatty's Avatar
burnafatty
Default inch pounds to foot pounds?
I just did an oil change on my fatboy and the torque seems to light! How do I convert inch lbs to foot lbs and do some of you just go by feel?
Old Jul 14, 2007 | 05:30 PM
Tripper's Avatar
Tripper
Default RE: inch pounds to foot pounds?
Divide inch-pounds by 12 and you will get foot-pounds.
Old Jul 14, 2007 | 05:31 PM
Texian's Avatar
Texian
Believe you just divide the inch pounds by 12 to get foot pounds.
fatboylust's Avatar
fatboylust
12 inch pounds equals 1 foot pound. Wrench tight is probably good enough, I assume you are talking drain plug and o-ring seals the joint so just enough torque to retain the plug.
FBL
Old Jul 14, 2007 | 05:37 PM
burnafatty's Avatar
burnafatty
252 inch lbs seem a little high, also put on some teflon paste is that cool? 150 inch lbs seem about right.
Old Jul 14, 2007 | 06:12 PM
easyriderone's Avatar
easyriderone
Go to Sears buy you a foot pound torque wrench, Sears usually runs them on sale for around $59. Anybody with a Harley should own two, a foot pound one and a inch pound one. Always put a little Telfon paste on all your drain plugs (oil, tranny and primary). The lowest setting on the Sears foot pound torque wrench is 15 foot pounds, thatis enough torque on your drain plugs. For anybody who wants to do their own service the Fix My Hog series of DVD's is excellent. The DVD's will give (by showing exacting what to do)you pretty much all the info needed to service your own bike.
Old Jul 14, 2007 | 06:52 PM
JLHOG's Avatar
JLHOG
http://joshmadison.com/software/convert/
Old Jul 15, 2007 | 08:42 AM
thrillseeker's Avatar
thrillseeker
I use this web site for all types of conversion needs... bike and non bike related.
http://www.onlineconversion.com/
Old Dec 28, 2018 | 05:45 AM
sneha rani's Avatar
sneha rani
Stage I
I Suggest to use this unit converter to get quick and accurate measurement conversion.
Old Dec 28, 2018 | 06:51 AM
Notgrownup's Avatar
Notgrownup
I hand tight with paste and new o ring. Maybe overkill but 92000 miles no drip and still the same drain plug. Now I have a new motor so I start again. I’ll revive this post in 10 years to report.
