Oil Archive (no new posts) An archive of oil related questions and comments.
Screamin eagle oil pump alignment
Old Jan 21, 2021 | 01:24 PM
THE GAS STATION's Avatar
THE GAS STATION
2nd Gear
Thumbs up Screamin eagle oil pump alignment
Well my oil pump grenaded and i messed up bad really bad my new s&s crank is slightly damaged i have a cam plate screw stripped out and my ego has been kicked in the dirt, I do fix it but not before i have to find the problem which i thought was the head and or piston then removed primary then oil pump which i finally found cracked and broken in a bunch of pieces i have a youtube channel with a build series of vlogs that i have been working on for a year or two on my FXDC 2014 Dyna Super Glide from a dual disc cheap build to building the motor with a 107 Mackie and Barnett clutch installation i have a list of videos and soon races with the fellas coming up soon..
Check my channel out if you like but here is a video on what i had to do with my oil pump which i had to install a new one and do some other stuff as well ..thanks everyone
Old Jan 29, 2021 | 07:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I tried to read that run together mess, but I gave up.
It appears that the only reason you post on this forum is to promote your youtube channel.
Old Jan 29, 2021 | 10:22 AM
big cahuna's Avatar
big cahuna
It's hard to watch "How To " videos , made by some guy that doesn't know what he's talking about. Doesn't know the correct name of the parts he's working with, or the name of the tools he's using. You can tell they're pro's from the flip flops they're wearing ,and how they sit on a dirty garage floor with the engine covers open. And you can always believe they are correct about torque values. Some people actually know their stuff, but I would rather have my eyes poked with sharp sticks then listen to the Fix my Hog guy, talk about anything.,,,
Exit45
Exhaust System Topics
Sep 15, 2019 12:36 PM
langwilliams
Engine Mechanical Topics
Apr 30, 2019 02:17 PM
smajr
Sep 8, 2014 06:46 AM
madhunter60
Feb 6, 2013 05:44 PM
electraglidenblue
Jul 16, 2007 01:26 AM
