Oil Archive (no new posts) An archive of oil related questions and comments.
Oil test
Old Aug 26, 2022 | 08:57 AM
user 47363638's Avatar
user 47363638
Default Oil test
Did an oil change and figured I would use a few different oil’s and see which one is better, hope nothing bad happens.
Old Aug 26, 2022 | 09:13 AM
CaffeineBuzz's Avatar
CaffeineBuzz
i've been using a cheesy cheep oil catch, doesn't even hold all of the oil, primary and trans, i have to empty between draining.....yours looks like it hold the whole of the discarded fluids...i want one
i like what you're doing....combining the strengths and advantage of each brand oil by combing them into one super oil.....you my friend my have won the internet, today, with that genius idea
Old Aug 26, 2022 | 10:43 AM
Tired's Avatar
Tired
I sometimes mix the oddball leftovers. No use tossing good oil. Miraculously, nothing has ever exploded.
Old Aug 26, 2022 | 11:36 AM
Calif Fat Bob's Avatar
Calif Fat Bob
@Ironworker69 You've gone and done it now! Mixing oils will surely:
- Destroy your motor
- Void your warranty
- Cause a loss of HP
- You will never find neutral again
- Your clutch will slip
- Your forks will sag
- Your tires will wear faster
You sir might as well just burn that bike as it will never run right.
(in before someone posts a link to some oil test showing Amsoil is the only oil to use. lol)
Old Aug 26, 2022 | 11:53 AM
M Oclaf's Avatar
M Oclaf
Amsoil = snake oil...just change it and run weights recommended. Nothing is better than the other especially cost wise.
Old Aug 26, 2022 | 05:12 PM
user 47363638
It’s a Harbor Freight special, it’s a little tight underneath, hence the wood under the tires.
Old Aug 26, 2022 | 05:44 PM
mjwebb's Avatar
mjwebb
Old Aug 26, 2022 | 06:10 PM
Rocking_it's Avatar
Rocking_it
With the price of gas coming down, anyone can now afford to experiment.
Old Aug 29, 2022 | 07:59 AM
bustert's Avatar
bustert
WHY?????
all ready done sooooo many times, like beating a dead horse to get up.
Old Aug 29, 2022 | 08:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I don`t get it.
