Oil Archive (no new posts) An archive of oil related questions and comments.
Changing Oil Cold
Old Mar 14, 2023 | 08:49 AM
hd4evr2008's Avatar
hd4evr2008
Default Changing Oil Cold
My bike is sitting in the garage and it's about 30 degrees outside. I need to change the oil because Winter caught up with me last year before I could get it changed. Can I go ahead and change the oil cold? Just pull the drain plug and let it drain for a couple days? Or wait to warm it up when the weather breaks? I read somewhere that cold oil changes are actually better, especially after sitting all winter, because all the oil is drained to the bottom and all the contaminants are down in the bottom end too. Starting the bike will just redistribute them into the top of the engine. What are your thoughts? Can I just go ahead and drain it cold? Just getting sick of winter, and I want to tinker with my bike. I can let it sit for 2 or 3 days and drain so all the oil should drain by that time. Thoughts?.
Old Mar 14, 2023 | 09:06 AM
strych9's Avatar
strych9
IMHO. a cold oil change is a worthless oil change. Old oil will cling to surfaces inside the engine. Changing oil hot is the better way.
Old Mar 14, 2023 | 09:10 AM
Crabchuck's Avatar
Crabchuck
Really? So it was shut off cold? Or was it that once the oil was cold, it climbed back up into the engine on it's own to cling?
All the oil that was going to drain down to the pan is already there. Change it cold, it'll be fine. It'll be a little thicker than hot, so it will take longer to drain. Pull the plug and leave it for a couple hours to drip.
Old Mar 14, 2023 | 09:23 AM
Rogue1's Avatar
Rogue1
Crabchuck is absolutely correct. Drain the oil just give it a little more time to drain before your button it up and you won't have a problem.
A lot of people look for a problem that isn't there.
Old Mar 14, 2023 | 09:24 AM
OKMICK's Avatar
OKMICK
Current score: Cold 2, Hot 1.
Old Mar 14, 2023 | 09:26 AM
Rogue1's Avatar
Rogue1
I'm not saying change it when it's cold. I change mine when it's hot. But changing it when it's cold is no big deal.
Old Mar 14, 2023 | 09:27 AM
mjwebb's Avatar
mjwebb
stop to consider why every manufacturer of ICE engines recommend checking and changing oil after it has reached normal operating temperatures..this thread can be closed now
Old Mar 14, 2023 | 09:28 AM
strych9's Avatar
strych9
It isn't rocket science.
OKMICK's Avatar
OKMICK
Hot ties it up at 2 each. This may go down to the wire.
cycleman11's Avatar
cycleman11
I've had to do a cold oil change a few times due to circumstance, so I'm with the go ahead crowd, and change it cold. Make sure you change out the filter as well.
