Amsoil White Sheet
Thanks iclick. I wasn't aware that RP used the same test.
Ron
I use Amsoil and think it's a good product overall. Some oils may be better at some things than others, but none are great at everything. My only complaint with Ams is it appears to be slightly weaker in viscostiy that say HD 20/50 dino. The engine was ever so slightly noisier when I changed. I attribute this to possible more lifter bleed down. Would I go back, hell no, but may consider purchasing the Ams 60 weight and add 1/2 quart per change to thicken it up a bit in the hot summer months. Just because some oils have moly, or tons of zinc,phosphorousetc, they can also have a negetive effect down the road with all the different metals in the engine. Moly may cause valve sticking, Zinc has been known to eat certain main and rod bearings and phosphorous (sp) can do a number on bronze bushings. I'm happy with the formula of Ams and will stay with it.
Ron
Your suggestion that moly "may cause valve sticking" is the first such suggestion I've heard in 45 years of accumulating knowledge of cars and MC's. Could you provide some sort of evidence to support this notion? I'm not doubting your claim without a fair trial, but just want more info on the subject, as I'm here to learn. It is interesting that if it indeed causes such problems there should be lots of cars on the road with sticking valves, and I haven't heard of any. Moly is a very common additive in modern oils, and AFAIK zinc and phosphorus are in nearly all oils, including Amsoil. Your assertions about zinc and phosphorus are new to me, too.
[hr]
iclick: I realize they are chemical compounds, not some old farm wife with a paring knife cutting chunks of metal off and adding it to oil.
Could not find the aircraft article on moly andvalve stickingbut found something more disturbing about it. I found it interesting and unexpected.[/align]Moly in Engine Oil, Check out the OEM bulletin from Cummins. It is the Cummins Engine Oil Recommendations, Bulletin No. 3810340-02 . Its probably best if you stopped by a Cummins Dealer and purchased this bulletin- about $2 or $3.
On page 7 it has a section on FRICTION MODIFIERS states:
"There is firm evidence that certain friction modifiers, molybdenum dithiophosphate for example, can in certain formulations result in cam follower pin failure at relatively low mileage"........
From years working with engine test programs to approve engine oil formulations for API licensing, we can tell you that NO engine oil containing Molybdenum additives has been certified by the full range of engine tests necessary to gain API approval.
Molybdenum compounds in motor oils can degrade and cause bearing corrosion and is particularly aggressive towards copper. In almost all cases, any engine oil formula having "moly" will also contain a Copper Deactivator which will protect bearings from the moly compounds. The only problem, the copper deactivator decomposes at relatively low temperatures and looses it's potency after a few thousand miles.[/align][/align]iclick: I have to point out that none of these additives are needed unless metal to metal has happened as in flat tappet camshafts on startup. Until then they are useless.. All bronze bushings contain lots of copper as in wrist pins , valve guideswhich leads one to believe oil selectionis a lot morethan picking one with the most antiwear ingredients like moly. Let's face it regular HD 20/50 dino has almost nothing worthwhile in it other than crude. The engine will still go 100k, but due to heat it should be changed more often. If you put the oil in a small block chevy, the cam would be gone in a couple of days. Bring on the zinc.[/align]Ron[/align]
The one fact that nobody has mentioned is the fact that AMSOIL's tests where done using ASTM Federal Testing Standards.
One question for you though; I noticed that you used Amsoil Motorcycle for the comparisons. Is this oil different to Amsoil MCV?
I have also read the oil report from bobistheoilguide and I noticed that he too tested Amsoil Motorcycle.
The problem some of us have with the White Paper is that (1) it was sactioned, designed, and paid-for by Amsoil
I will say this though..... and forgive me if someone has already pointed this out, but when I read the tests from the link above to the xlrator website done by Blackstone labs, I noticed what seemed like 90% of the oils tested were taken out of "Motorcycle Consumer News, Oil Investigation Update. 2003", while only four or five of the oils were tested by Blackstone.
Anyway ... on this thread we have a prime example of the problem: "I use Amsoil and have never had any problems, therefore Amsoil is the best!". Well I have news for you. I have a friend's 1968 XLCH at home (almost identical to my own) that has had nothing but the cheapest 60wt that the owner could find in it. It's been ridden the better part of it's 40 years and is just becoming tired. Am I to therefore believe that K-Mart branded recycled oil is therefore the best? Frankly I think riders, especially H-D riders, do more damage to the engines by blipping the throttle at stoplights than they ever will with the wrong oil.
A little bit of the Amsoil BS is exposed on the Spectro Oil web site in the letter section. I came across it by checking out oil companies web sites. Real important is to use Internent Explorer not Foxfire because they have a old web site, Google Spectro Oil, click on letters and check maybe half way down the page. I don't like people that try to BS me into using their product!
http://www.spectro-oils.com/letters.htm
I read your charts and was wondering why you do not list Amsoil for comparison also?
Bob
Check out the 'letters' page on our site for more info about this (below)....you will see an Amsoil graph that depicts their oils as having the highest content of ZDDP additive of allmotorcycle oils....this is completely a false statement.
Compare these ZDDP numbers for their 20w50 oil to our numbers for our 20w50 oil on my graph and you will see.
You will see that they also like to compare our oil to their oil, but, they chose to do it in the most misleading way possible....by choosing our synthetic 5w40 racing oil to compare with their 20w50 oil for a street Harley. We beat all their oils for ZDDP additive content and when compared fairly, 20w50 to 20w50, we also beat their oils in the 4 ball wear tests.
[hr]
...From years working with engine test programs to approve engine oil formulations for API licensing, we can tell you that NO engine oil containing Molybdenum additives has been certified by the full range of engine tests necessary to gain API approval.
http://www.valvoline.com/products/Maxlife.pdf
I'm sure there are probably others as well...
So honestly... It looks like SPECTRO oil is the best choice for bike oils.
