Oil Archive (no new posts) An archive of oil related questions and comments.
Thread Sealant
Old Jan 17, 2006 | 12:25 PM
srigas's Avatar
srigas
Default Thread Sealant
Do you seal your oil drain plug, primary drain plug and transmission drain plug with a pipe sealant? I've heard it's a good idea to do so, but I'am unsure as to the brand to use to do an effective job.
Old Jan 17, 2006 | 02:35 PM
bobcowan's Avatar
bobcowan
Default RE: Thread Sealant
Not sure about the TC's, but the Evo's had O rings on the trans and engine drain plugs. The primary is a pipe thread. Be sure to use sealant on the primary. On the plugs with an O ring it isn't necessary - but I did anyway.
May favorite is a non-hardening teflon paste.
Old Jan 17, 2006 | 02:49 PM
srigas's Avatar
srigas
What brand of paste do you use?
Old Jan 17, 2006 | 03:34 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: srigas
Not necessary on the engine and trans, they have "O" rings, the primary is tapered and it wouldn't hurt as it has to be kept above the surface of the cover as specified to avoid contact with internal parts.> THIS <will work for you.
traildog
2014-2024 Touring Models
36
Dec 22, 2017 07:49 PM
JohnFlorida
EVO
11
Jun 1, 2012 01:17 PM
big_e78
Nov 29, 2009 07:48 AM
Kabear
Jan 25, 2009 09:59 AM
crzrlou
Jan 13, 2008 04:01 PM
